Page 1 of 2 12 LastLast
Results 1 to 25 of 39
Like Tree3Likes
    Reece Curtis's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Samsung Galaxy Note 2 won't charge?
    Hi Guys sorry if in the wrong place. But my SGN2 has suddenly stopped charging. I only got the phone just over a month ago. I think it's the USB port as a couple of days after getting the phone I noticed sometimes it would stop charging like a loose connection but never really got round to getting it looked at as been really busy. I got the phone on contract from Phones 4 U and was wondering what I should do. Do I take it into the Phones 4 U store? am I still covered on a guarantee or w.e?
    Thanks Guys
    Reece
  2. Thread Author  Thread Author    #2
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Samsung Galaxy Note 2 Wont charge?
    Just to add when the charger is connected it shows that it's charging but it actually isn't. The battery has been going down whilst on charge and has now turned off and is once again showing its charging but wont turn on after at least 15-20 mins.
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Not even showing as charging now :@
  4. #4
    ihateskies's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    It's happened to a few of us... see this http://forums.androidcentral.com/sam...nt-charge.html
  5. #5
    Maverick Martin's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    My Note occasionally will not start after I have drained the battery to zero. This usually happens when I am playing Monopoly and cannot see the battery indicator and for some reason I do not receive any warnings that the battery is low, or maybe I just ignore them because the evil car driver is buying all of the railroads! Sometimes I can have the phone plugged into a charger but the game drains the battery regardless. I have determined it is the charger's fault. I use the charger that came with my headset to charge my phone when I am upstairs and a different charger when I am downstairs. The downstairs charger is rated at 550 mA and the upstairs charger is rated at 180 mA. When I plug my phone into the downstairs charger it will immediately begin charging the phone. So make sure you are using a charger with enough amperage to kick the charging circuit into gear. I have no idea what that threshold is but it is more than 180 mA.
  6. #6
    manhek's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    My battery got drained and wont charge. Tried with different plug points and chargers. Any ideas before i take it to the shop?
  7. #7
    Nico350Z's Avatar
    Posts
    Global Posts
    17 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I work a bit with PCB boards and stuff of that nature. I had this same issue with my Verizon Note II. It wouldn't charge when connecting the microUSB, I opened up the phone and found that the phone has it's own modular charging board that has the microUSB port and mic on it. With a magnifying glass I did find small imperfections on the solder joints but they were to small to fix. Usually this is from either water or shock damage, simply dropping your phone at the right angle can cause this issue. An old trick in the field is to bake your components..
    I preheated the oven to 350 and placed the board on a tray and baked for 5 minutes.
    (This will resolidify the solder and fix any imperfections)
    I reinstalled the board and viola! works 100% again. Hope this helps anyone daring to try, just remember, you void any warranty by opening it up so only do it if it's your last resort.
    Here's a pic of board that needs to be heated or replaced:
  8. #8
    Mohamed Ameer's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    okay i was experinsing the same problem and what i did was , took a pin and scraped the micro usb port pins now it charges like a baby maybe it might work
    KING_ERBZZ likes this.
  9. #9
    djkdawg's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Mohamed Ameer View Post
    right on the money, you could clean it with some alcohol also, pretty much what i did.
  10. #10
    Paul88x's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I had the same problem: it would sometimes stop charging like a loose connection. Putting pressure on the connection in a certain direction would cause the phone to charge while holding it. In the end I fixed this by BITING DOWN ON THE CONNECTION END OF THE CABLE, gently, to make it slightly narrower. This made a more "snug" fit when plugged into the phone and it works. It.also worked with another wire that was not connecting very well with a 3rd party dock.
    I'm not saying this is perfect but it worked for me. I'm no longer regretting the note2 like I was doing last week when it wouldn't charge normally.
  11. #11
    bunnybash's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I am buying a Qi charger and receiver pad cause I have had and seen too many problems with the usb ports develop over time.
    Sent from my GT-N7100 using Tapatalk 4
  12. #12
    Cliff Chapman's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I have my phone beside me in bed and I think the cable got twisted - swapped for another Samsung charger and all fine.
  13. #13
    Brandon_28's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    you did that on the phones charge port or on the charger?
  14. #14
    ComradeZ's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    This happened to mine last night RIGHT after a rom swap.
    I'll try the oven. works for video cards and xbox360s..might as well try this
  15. #15
    Biswanath Das's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Reece Curtis View Post
    Thanks Guys
    Reece
  16. #16
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thank u guys .I got scared , I bought the note 2 only 2 month back .As per ur suggestion I took a safety pin and scrap inside the usb chrging port and also the cable .ola is charging ***
  17. #17
    Martyboy84's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    first ever post, just wanted to say thank you.
    I had been out mountain climbing yesterday (as you do lol) and it the weather was wet and we had blizzards including temps below -9.
    Got back to the house and my phone wouldn't charge.. Left it over night, same issue. NOTHING..
    Whenever I replugged it in, for a second the dead battery icon would load and my charger would make the sort of humming noise.
    I found this thread, tried scraping the USB connector on the phones side.. annnnd whalla!!!
    Thank you for that, probably not the most scientific way, but it worked.
    (I should stress, I wasn't overly aggressive with it, I was not to firm or harsh)
  18. #18
    Martyboy84's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I take it back .
    It just stopped charging at 15% and won't do anything else.
    It also flags up as "usb connected".
  19. #19
    dpham00's Avatar
    Posts
    Global Posts
    24,790 Global Posts
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Have you tried a different cable and charger?
    Sent from my Verizon Samsung Galaxy Note 3 via Tapatalk Pro
  20. #20
    transistors's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
  21. #21
    DesElms's Avatar
    Posts
    Global Posts
    117 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by transistors View Post
    I'm sorry, but that thread's first two posts -- by that thread's starter (aka, its "original poster" or "OP") -- are just ridiculously wrong and misleading.
    I have, however, added a third post to that thread which sets straight the record; and provides any Samsung Galaxy famly phone user -- particularly a Note II user -- with pretty much everything s/he needs to know about this subject.
  22. #22
    Alia Pedigo's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I am having the same issue
  23. #23
    sMt73's Avatar
    Posts
    Global Posts
    161 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    To avoid this, I bought a receiver pad for my note 2 battery, and a Nokia charging plate. Plate cost me $22.00 at local AT&T store. The QI receiver for the battery cost $6.99 from Amazon. Took less than a minute to install and have been enjoying cord free charging for over a month now. I have had this issue on several phones, HTC, Samsung and LG. The port you connect the cable to on the phone is fragile. Hope everyone get's there charging issues figured out.
  24. #24
    Stewart grainger's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    hi i got same problem with mine i got mine <deleted> today they say its not covered by warranty so its going to cost 45 i think its a joke they said its my fault the damage
  25. #25
    Joell Love's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    My Note 2 will not charge either. Tried cleaning USB port...nada. When I first plug it in the charging battery pops up for a second while the loading icon does not spin. Anyone have any ideas.
  1. Samsung galaxy note phone - usb charge flex power port problem
    By mceochaidh in forum Samsung Galaxy Note 2
    Last Post: 02-21-2014, 11:55 PM
  2. Samsung Galaxy Note Phone Charging
    By CliveRoberts in forum General Help and How To
    Last Post: 01-25-2014, 01:41 PM
  3. Help! My new samsung galaxy note 2 wont send txts!
    By Ronald Manganaro in forum General Help and How To
    Last Post: 02-18-2013, 08:06 AM
  4. Samsung GALAXY NOTE 10.1 / GT-N8000 Charging Cable dos it work with the tab p7510
    By Justin Boland in forum Samsung Galaxy Tab 10-inch
    Last Post: 01-26-2013, 03:51 AM
  5. Palm Gray Wireless Charging Back Cover+Dock for Samsung Galaxy Note 2 N7100
    By grassysparkie in forum Samsung Galaxy Note 2
    Last Post: 12-28-2012, 09:34 AM
