Results 1 to 7 of 7
    Default Smart Keyboard voice to text issues on Note 2
    For some strange reason the voice to text feature for the Smart Keyboard app is no longer working on my Note 2.
    I tried it on my Nexus 7, and it works fine.
    I uninstalled the app, then reinstalled it. Still can't get it to work. It constantly says "No matches found" when I try to use the voice to text feature.
    Anyone else having this issue if you happen to have Smart Keyboard Pro installed on your Note 2?
    Sent from my Samsung Galaxy Note II using Tapatalk
  2. #2
    Default Re: Smart Keyboard voice to text issues on Note 2
    Try a factory reset. Sounds like a glitch and resets are good at fixing issues.
    Good luck!
    Sent from my Samsung Galaxy Note2
    sent from either my Samsung Galaxy Note2 or my
    Samsung Galaxy Tab 10.1
    Finally got it to work again.
    I kept uninstalling and reinstalling it to no avail. I checked all of the voice recognition settings in language and input. Still no luck.
    Decided to download the Trial version of Smart Keyboard and it worked. Removed the trial version and reinstalled the paid version, and it started working again.
    During the time it wasn't performing as it should, it gave me a chance to check out SwiftKey. I rarely used SwiftKey, but after having some time to play around with it, I'm starting to like it.
  4. #4
    Glad for ya!
  5. #5
    Just talked with Verizon. The issue was my choice under Language and Input. Go to Settings, Language and Input, then look at what you have as the default. I had Swype, but he had me change it back to Samsung Keyboard. It still has Swype capabilities, but voice to text was successful for text messages. I like Swype better, but this is manageable as long as the voice to text works. Hope this helps you.
    Quote Originally Posted by SoCalCurlyQ View Post
    The issue was with a 3rd party app called Smart Keyboard. At the time, voice to text was working fine with every keyboard except Smart Keyboard. I eventually got it to work after resetting my device.
    I'm not sure if Smart Keyboard still have issues as of late, since I use SwiftKey and Google Keyboard as my daily drivers now.
    Sent from my SCH-I605 using Tapatalk 2
  7. #7
    I used Swype as my keyboard since my Samsung Vibrant (the original Galaxy) I used it on my S2 as well. Then I got my Note 2. I used Swiftkey,Swype, the Samsung keyboard and it was great but then Google released there keyboard on the play store.
    I've been using Google Keyboard ever since. It's by far the best keyboard I've ever used. It's fast, no lag, the predicted text is spot on, as well as the auto correction. It also seems when I use the voice typing it's more accurate. I also like how you can import to you're dictionary. The great part is it's only going to get better oh and it's free! You can't beat it...
    Sent from my SGH-T889 using Tapatalk 4 Beta
  1. Note 2 keyboard and voice to Text
    By ItsaRaid in forum AT&T Galaxy Note 2
    Last Post: 04-14-2013, 09:43 AM
  2. Keep Voice to Text key on keyboard?
    By lgreenberg in forum Samsung Galaxy Note 2
    Last Post: 11-11-2012, 10:29 PM
  3. talk to text icon on keyboard disappeared?
    By spencer0279 in forum Motorola Droid
    Last Post: 07-11-2011, 08:06 AM
  4. Voice to text on 3D
    By packpackpack in forum HTC EVO 3D
    Last Post: 06-30-2011, 11:14 AM
  5. Voice to Text Features in Android on Moment?
    By robbies7897 in forum Samsung Moment
    Last Post: 03-21-2010, 05:54 PM
B
