Results 1 to 3 of 3
    Angry Cant take incoming calls, please help!
    Hello all
    I have a problem on my new Note 2.
    I cannot answer *some incoming calls (NO RED AND GREEN ANSWER OR DECLINE ICONS APPEAR).
    This happens in either the lock screen or on the desktop, makes no difference.
    I say 'some' calls, I had 2 calls yesterday fro different locations that I know where from automated sources (like call centres).
    I took a call from my other half sometime later with no problem.
    Does the Note 2 know they're from dubious sources and not give you the option to answer them? I doubt it..
    This is not just that I don't understand you have to swipe the answer icon, the icons never appeared.
    The 2 numbers called about 3 or 4 times each, no option to answer them.
    I have also enabled the 'answer with home key' feature and this din't answer the call either..
    I'm a bit concerned that I'm going to miss a call I really need to take.
    Very frustrated, can anyone help me please?
    Many thanks.
  2. #2
    Default Re: Cant take incoming calls, please help!
    I have the opposite problem. I can't hang up or get the screen to come alive to hang up a call or be able to type in numbers.
    I think the proximity sensor or something is screwed up. I think this happened around the 4.1.2 upgrade, at least for me.
  3. #3
    I am having that same problem right now, my screen does not come on when I remove the phone from ear, I had to take the battery out and reboot it
    Sent from my SPH-L900 using AC Forums mobile app
  1. Replies: 14
    Last Post: 12-03-2013, 09:44 AM
  2. Cant get into recovery (please help)
    By sschreibeis in forum Thunderbolt Rooting, ROMs, and Hacks
    Last Post: 08-05-2011, 11:21 PM
  3. Cant install custom recovery. Please help
    By scottypeterson in forum LG Optimus S Rooting, ROMs, and Hacks
    Last Post: 07-12-2011, 01:31 PM
  4. post 2.2.1 update, cannot make calls. please help
    By lster in forum Sprint Epic 4G
    Last Post: 02-26-2011, 08:08 AM
  5. Replies: 0
    Last Post: 12-31-1969, 07:00 PM
