1. Mohammed A's Avatar
    I have a question about the charging for the note 2. My dad's note 2 had a blinking blueish LED light while the screen was off and the phone was plugged in AC but then 10 minutes later after I unplugged the usb cord from the power outlet the LED light was a solid red while charging?? Is there a difference between the two lights?
    Also, he told me while he charges his phone in his car that the beeping noise comes on repeatedly and that the phone does not charge well enough. What could the problem be??
    06-05-2013 06:01 PM
  2. Golfdriver97's Avatar
    It might be a physical problem with the connector. Do you have another charger to test?
    06-05-2013 06:03 PM
  3. Mohammed A's Avatar
    My father used different wires and carport chargers. He told me that the phone would sometimes just make that beeping noise continuously, the noise you get when you plug in a usb.
    06-05-2013 06:19 PM
  4. Golfdriver97's Avatar
    Overall, I guess the real question is, is there a problem with charging? Does it take longer or shorter to fully charge?
    06-05-2013 06:55 PM
  5. JenTDOT's Avatar
    My Note 2 has a flashing blue light if there is a notification while charging. It will be solid red if there are no notifications.
    I noticed that *after* checking a notification whe charging, the light will go off entirely, and not show any led. Not even the green that indicates it is fully charged. Not sure why.
    Sent from my SGH-I317M using Android Central Forums
    Mohammed A likes this.
    06-06-2013 01:41 AM
  1. Evo charging problems
    By logicalform in forum HTC EVO 4G
    Last Post: 09-23-2010, 12:19 AM
  2. Bump charging problem...
    By nneptune in forum Verizon Droid Incredible
    Last Post: 06-25-2010, 10:28 AM
  3. Charging Problems (OEM Charger)
    By illwood in forum HTC EVO 4G
    Last Post: 06-22-2010, 03:40 PM
  4. battery charging problem
    By bnesws757 in forum Motorola Droid
    Last Post: 06-17-2010, 10:21 AM
  5. odd charging problem....
    By clafountaine in forum HTC EVO 4G
    Last Post: 06-09-2010, 02:45 AM
