Results 1 to 5 of 5
    Default Storage space running low.. How to delete downloads
    I have the Utorrent app which is use to download music and some videos to my note 2. Now I've been a pop-up saying my storage space is running low so when I go to my storage settings it says that the downloads section has 7 GB of data which is the problem, now when I click on it to view the downloads it shows up as empty on both downloads and Internet downloads, I'm wondering if there is a way to find these downloads and delete some of them or move them to my SD card which has tons of room.. Any help or advice would be appreciated
  2. Thread Author  Thread Author    #2
    Default Re: Storage space running low.. How to delete downloads
    Found an app that works called my file it allowed me to delete the files that had been downloaded without removing them from my music player altogether, I knew that my amount of music wasn't 6gigs worth
  3. #3
    I have the same problem, did you find a solution?
  4. #4
    Can you not put your music on your SD card through "my files" also?
  5. #5
    GeekCop's Avatar
    Posts
    Global Posts
    186 Global Posts
    Don't use your internal storage for music. You'll run out of space in no time. Go with the previous poster's suggestion. I don't actually keep music on my N2. I have it all on iTunes, which I access via Google Play Music
  1. Installing sd card from my old phone to my s4
    By jerkyg in forum Samsung Galaxy S4
    Last Post: 10-12-2013, 04:01 AM
  2. HTC One Sync Manager Load iTunes music to phone?
    By New_2_Andriod in forum HTC One
    Last Post: 09-06-2013, 10:28 AM
  3. GS4 / touchwiz customization questions
    By kabutar in forum General News & Discussion
    Last Post: 07-09-2013, 11:04 PM
  4. Replies: 0
    Last Post: 07-09-2013, 10:33 PM
  5. OS updates are still very important to android enthusiasts
    By Rule9 in forum General News & Discussion
    Last Post: 07-09-2013, 09:43 PM
B
