08-13-2013 04:53 AM
50 12
tools
  1. LadiJae's Avatar
    The only non battery draining Weather app so far is the stock one. Only after i turn everthing off.....Which is ugly and doesn't go with any wallpaper.
    Are there any that don't have maps waking the phone every second????????
    ~Jae, tap'n on my Sexy White Galaxy Note 2~
    07-10-2013 08:23 AM
  2. dellagregg's Avatar
    I use go weather ex. Its not draining my battery. Also when you try other weather apps do you change the setting of how often they update and if they are using your gps? These two being on the wrong setting will drain battery even on the stock app.
    Sent from my gorgeous Galaxy Note II aka CJ. <3
    07-10-2013 10:24 AM
  3. LadiJae's Avatar
    I turn everything off. No updates no nothing.
    07-10-2013 10:49 AM
  4. LadiJae's Avatar
    I just Unistalled go weather
    07-10-2013 10:50 AM
  5. sonyscaria's Avatar
    I use weather bug. Update interval set to 1 hr. I am a heavy user and no concerns.
    Sent from my GT-N7100 using AC Forums mobile app
    07-10-2013 11:19 AM
  6. Trees's Avatar
    Weatherbug is good. I had no battery issues when I had it installed. Am currently using eWeather HD, which is probably a weather geeks type of app. Tons of features and options. Like dellagreg and sonyscaria noted, polling frequency and methods can make a difference.
    07-10-2013 06:23 PM
  7. MercuryStar's Avatar
    I really like Weatherwise and its widget uses less battery (and less data!) than my previous weather app while being more functional.
    It has colour codes for telling the upcoming weather in the next 24 hours or so: green = rain, grey = cloudy, orange = sunny, purple = clear moon, white = ???
    07-10-2013 09:58 PM
  8. anon(6174973)'s Avatar
    Use weather bug without auto update. Works flawlessly.
    Sent from my GT-I9505 using Tapatalk 4 Beta
    07-10-2013 10:02 PM
  9. almath's Avatar
    I use Fancy Widgets, I like it no battery drain and you can configure to your liking.
    LadiJae likes this.
    07-10-2013 10:45 PM
  10. juicersb's Avatar
    yeah,I use weather bug. Update interval set to 1 hr. I am a heavy user and no concerns.thanks
    07-11-2013 01:24 AM
  11. anon(6174973)'s Avatar
    But what I like most is Accu weather because I can see the weather by hour.
    07-11-2013 07:18 AM
  12. LadiJae's Avatar
    I think I have an obsession with seeing the wake locks on my phone of apps. And it drives me crazy. That mapa is in the thousands and any weather widget I add is in the hundreds even with the interval set to not update
    07-11-2013 08:51 AM
  13. anon(6174973)'s Avatar
    Do you enable the feature of having the temperature set at notification bar?
    Sent from my HP Slate 7 using Tapatalk 4 Beta
    07-11-2013 08:55 AM
  14. LadiJae's Avatar
    No , I leave Everything off
    07-11-2013 10:10 AM
  15. anon(6174973)'s Avatar
    I'm not so sure about that. All I can think of is the app constantly starting up.
    07-11-2013 10:37 AM
  16. prepaidguy9081's Avatar
    I find the idea of a non battery draning app funny. If it runs it drains, period
    I use accuweather+ for lock screen and go weather for next launcher.
    Ofcourse im rooted, with cpu govener profiles for underclocking and greenify hibernation app.
    So my batt life is awsome even though I do apparently retarted things like turn the screen to max performance and run two weather apps.
    Sent from my SGH-T889 using Tapatalk HD
    07-11-2013 02:07 PM
  17. anon(394005)'s Avatar
    I've been using BeWeather Pro for about a year on all my Android devices and haven't noticed any battery drain issues on any of them. I use a 4x2 widget on the main screen set to a three hour auto update interval along with the temperature in the notification bar. All other settings (in the app) are disabled.
    07-11-2013 04:43 PM
  18. blitz118's Avatar
    The Note 2 has a 3100mah battery, so I don't worry about a weather app draining my battery, and I have my weather set to update every 30 minutes.
    07-11-2013 07:37 PM
  19. Trees's Avatar
    I think it's cool that you're digging in to the details to find out what may be consuming battery or other phone resources. I'm going to start a new thread about wakelocks
    07-11-2013 07:47 PM
  20. LadiJae's Avatar
    I wish it was that easy. Surprisingly yesterday I ended up with 14 hours on battery and 4hrs 45mins of screen time.
    07-12-2013 08:26 AM
  21. Lodingi's Avatar
    I doubt your issue is due to a weather app. I use the S4 widget (custom rom) and it auto updates every hour. I am also overclocked at 1.92 Ghz and I easily get a full days usage.
    07-12-2013 11:17 AM
  22. srvctec's Avatar
    I use Android Weather- great app with nice clean widgets and no battery drain issues with it set to update every 15 minutes.
    07-13-2013 12:21 AM
  23. prepaidguy9081's Avatar
    I get that without worrying about anything but cpu frequency.
    All other stuff I just ignore wheither it uses alot or not.
    sywalls likes this.
    07-13-2013 06:27 AM
  24. anon(6174973)'s Avatar
    That's not bad for a heavy user. Are you using the stock battery or extended battery.
    07-13-2013 06:33 AM
  25. prepaidguy9081's Avatar
    Ive been heavy using for the last three hours, off charger since yesterday morning. 37%
    Stock battery.
    But ive been keeping all antennas off except talk and sms
    07-13-2013 08:17 AM
50 12
  1. [APP] Drawcam - live photo effects app
    By calderwa in forum Android Apps
    Last Post: 04-15-2014, 11:41 AM
  2. Zerolemon battery for OGPro!
    By limitbreak09 in forum LG Optimus G Pro
    Last Post: 02-19-2014, 02:48 PM
  3. pdanet bluetooth tethering sucking my tablet battery fast!
    By Mitchell Gray in forum General Help and How To
    Last Post: 07-10-2013, 05:24 AM
