Page 1 of 2 12 LastLast
Results 1 to 25 of 27
    co24's Avatar
    Posts
    Default Verizon Note 2: Outgoing calls failing (+) plus sign added to incoming numbers in call log
    All incoming calls in Verizon note 2 come with plus sign on front of area code. If I try to call it won't go through, It recently started doing this. I even did a factory reset and nothing, please help.
    Sent from my iPad using Tapatalk HD
  2. #2
    Default Re: Outgoing calls failing (+) plus sign added to incoming numbers in call log
    Sounds like a carrier issue. On a mobile phone "+" is the equivalent of your international dialling prefix. If you start a number with "+" you need to follow it with the international country code, then the rest of the number as if dialling internationally (it's safe to do this even with local numbers; you won't be charged an international call cost).
    If incoming calls have a "+" at the start but don't have a valid international dialling code (eg "1" for the United States) preceding the rest of the number, then it sounds like a bug with the carrier.
  3. #3
    Did you ever got this problem resolved? I m in the same boat
    domush likes this.
  4. #4
    This is just a guess, but...
    Go into your Dialer, tap the Menu button, go into Call settings, then under Other call settings, do you have U.S.A. listed under both Current country & in the Assisted dialing settings?
    Sent from T4 in my N2
  5. #5
    Did you ever got this problem resolve this thread im in the same boat :
  6. #6
    Duard's Avatar
    Posts
    Carrier
    Stock
    Question Re: Verizon Note 2: Outgoing calls failing (+) plus sign added to incoming numbers in call log
    Hi, ameenhack. Please clarify, are you seeing the plus without the 1 in the incoming call log for numbers that are found in your contacts, for numbers that are not found in your contacts, or both?
  7. #7
    Default Re: Verizon Note 2: Outgoing calls failing (+) plus sign added to incoming numbers in call log
    Try disabling assisted dialing
    dpham00, Android Central Moderator
    Sent from my Verizon Samsung Galaxy Note 3 via Tapatalk Pro
  8. #8
    I'm in the same boat, using at&t with straight talk. All incoming calls have a + in front of the area code (without a 1). This only happens to incoming calls. The call log shows outgoing calls just fine, no + in front.
    I've tried assisted dialing settings, changing countries, changing roms. I'm at my wit's end. I need to be able to call people back!
  9. #9
    Same problem here. i called Samsung they said its network issue & I should contact AT&T. Per AT&T, technical support for phone not purchased from them is limited. Does anyone have solution to this problem? pls help.
  10. #10
    Hi there,
    Have you fixed the problem? I have the same issue and the carrier can not figure out what to do. I have done factory reset, and still the problem is there.
  11. #11
    Phone
    Phone settings
    Advanced phone settings
    Auto areacode
    Is this on or off, mine is off, no issues
    Tmobile note ii, unlocked, cricket wirless (att mvno), jedix20 rom, android 4.1.2
    Sent from my SAMSUNG-SGH-I317 using Tapatalk 4
  12. #12
    I found this issue to be a pain in the you know what and struggled to fix this issue for a few months. I finally fixed it today and thought I would share my fix.
    Go to Settings > Call> other call settings> Assisted dialing.
    Select the settings and delete all the details. Then toggle to off. Works on my Verizon Note 2 running AT&T Sim card through Straight Talk
  13. #13
    Red face Re: Verizon Note 2: Outgoing calls failing (+) plus sign added to incoming numbers in call log
    "Go into your Dialer, tap the Menu button, go into Call settings, then under Other call settings, do you have U.S.A. listed under both Current country & in the Assisted dialing settings?"
    Thank you, thank you! All better now.....
  14. #14
    can some one please help take the plus sign off, i'm unable to dial or send msg with the plus sign in front of the number
  15. #15
    It doesn't work for me
  16. #16
    kk1l's Avatar
    Posts
    It does not work for me either
    This one is driving me crazy. Prefixer does not work either. Always the + before each incoming number.
    Samsung Note 3 900V...ex-Verizon phone on Cricket (ATT) network.
    Quote Originally Posted by Mike Larry4 View Post
  17. #17
    Quote Originally Posted by kk1l View Post
    I am having the same issue with not just Note 2 but all the VZ Samsung using Straight Talk AT&T sims card. But when I put on VZ LG, iPHone or Droid Turbo phones, the incoming calls coming as as expected. Prefixer works ok but still not for replying text and incoming still has a plus. My test case includes VZ Note 3 - having plus but AT&T Note 3 does not which tells me Samsung somehow detects it's a foreign SIMs and automatically add the plus sign.
  18. #18
    Using VZ note 2 with ATT sim. Prefixer works to remove the + sign as long as you allow the Prefixer program to pop-up to show "call being handled by prefixer" before answering the call. I also had to add a third party answering service program since the existing one was tied to VZ service. Using InstaVoice which works great. On calls that get answered by InstaVoice the + sign still comes up on the missed call number. I have just gotten accustomed to doing a quick save of the missed call number if person left a message and not in my contact list. Once in contact list, remive the + and re-save. I don't seem to have any issues with + once the caller is in my contact list. Good luck. I was also not able to get my hotspot to work due to issue in a program that loads at bootup. Installed FoxFi and paid their fee once I tested it and found it worked. I am on a data plan with ATT that allows tethering and hotspot use so I'm legal with ATT. Thinking about changing to Straight Talk but getting the SIM that is Verizon network. Hoping some stuff might work better back on a Verizon network.
  19. #19
    it does not work for my galaxy s5, sm-900v
  20. #20
    Download an app called prefixer then open app and manually add rule to reject enter \+ it works!!!!!! Make sure to add rule to incoming and out going
  21. #21
    Can you please tell me step by step how to do this. I will application a lot. I been try all night but still never work .Big thankssz
  22. #22
    I have same issue and i tried everything in this thread non it works.
  23. #23
    Nightmare. I can't believe an Android phone would ship with such a bug. Bought phone at Best Buy, traveled to Europe, bought a local SIM card. All my Google contacts have + (country code) in front of them. I can dial numbers direct, but without the Plus Sign (+). I can't dial anything in my address book. Researched it and painfully so, I found a third party app (prefixer) that does the trick after trying a few. You basically want to add "00" in front of the +.
    It's simple enough, but I don't care for the fact that it's not native to the phone. Here is the configuration below - best of luck
  24. #24
    PB66's Avatar
    Posts
    In USA, Verizon Samsung Galaxy Note3 + sign added issue since porting to ATT. Prefixer finally worked! Weaving together portions of previous threads (thank you to all who contributed!) Here is my fix:
    In both Outgoing and Incoming Calls:
    under
    "When number matches"
    edit to ".+"
    then under
    "Remove characters"
    edit to "\+"
    So far working for returning all incoming calls and texts! Good Luck!!!
  25. #25
    Default
    Quote Originally Posted by co24 View Post
    App called IntlPrefix gixed this bug for me.
  1. Downloaded images don't show up in folder
    By BRVNDXN in forum Samsung Galaxy S3
    Last Post: 10-23-2013, 06:15 AM
  2. Galaxy Note 2 starting to have problems while unlocking
    By David Robinson7 in forum AT&T Galaxy Note 2
    Last Post: 09-26-2013, 11:31 AM
  3. $15 amazon gift code to whoever can help me root the ematic genesis prime
    By TapZoo Cheats in forum General Help and How To
    Last Post: 08-14-2013, 08:15 AM
  4. Replies: 11
    Last Post: 07-27-2013, 01:43 AM
  5. What app is putting ads in notification bar?
    By thehyperone in forum Android 2.3 Gingerbread
    Last Post: 07-22-2013, 09:55 AM
