1. philmair's Avatar
    The S Note app is one of the best features of the Note II - but the most annoying aspect of it is the VERY LOUD page turn transitions. There seems to be no way of turning the sound off (or at least turning it down) .. except muting the entire device .. which isn't very useful.
    Please .. have I missed something or is there a hack that can be applied. At present it's just plain embarrassing to read my notes in public !
    09-04-2013 06:38 AM
  2. RichardClark's Avatar
    I don't have a solution, but I can sympathize with your situation. I came here searching for an answer to the same question. Normally, I use S Note in a meeting situation where I have sounds muted. So I didn't notice until recently that it did make a noise and figured I had messed some setting up. If anyone has a solution to this annoyance, please share!
    09-11-2013 04:51 PM
  3. srvctec's Avatar
    Well, I came here looking for an answer, too. Apparently, it's not possible.
    05-04-2014 11:13 PM
  4. srvctec's Avatar
    I have found a work around for this. The Media sound is the culprit- when it's off (or set to zero), there are no page turn sounds. If you want it to stay this way, install Timeriffic from Play Store if you're not already using it (one of the best apps and first I install on any device). Set it to turn Media volume to zero percent every day or several times a day if you want. This will ensure that if you watch a video or play music at some point, the media volume will be back to zero. Or just remember to keep it at zero when finished listening to music or watching a video.
    05-10-2014 11:15 AM
  5. paul bandawe's Avatar
    This doesnt work on my Tab A. And "do not disturb" mode is active. very embarrassing indeed
    07-28-2016 10:14 PM
  6. Killzee1's Avatar
    It's a true problem. I hope it has been solved in the new versions. But in my phone the only way is to shut the sound of the phone.
    08-22-2016 06:25 PM
  1. how to root my galaxy music duos GT-S6012
    By pran gohain in forum General Help and How To
    Last Post: 01-09-2014, 02:22 AM
  2. gs3 no sound notification when text received
    By Alex Myers1 in forum Samsung Galaxy SIII I9300
    Last Post: 09-04-2013, 10:57 PM
  3. Alarm when phone is set to vibrate
    By johnnyshinta in forum HTC One M7
    Last Post: 09-04-2013, 03:52 PM
  4. How do I use NFC, like how do they know what to transfer??
    By eclein in forum Google Nexus 7 Tablet (2013)
    Last Post: 09-04-2013, 11:36 AM
  5. Best way to clean the white plastic surrounding?
    By Club Paradise in forum HTC One M7
    Last Post: 09-04-2013, 10:53 AM
