Results 1 to 5 of 5
    Default how do I find what is draining my battery
    i have a sgh-I317 note 2 running 4.1.2 and recently my battery has been draining fast.
    Used to be the screen was the thing that was eating up the most battery (when it seemed to last)
    now media and android system and andriod os are the big ones.
    how do I find out what program or what is kiiling my batter
  2. #2
    Default Re: how do I find what is draining my battery
    Try this out for size.
    If your rooted than this works fairly good
    Thanked by:
    thanks.
    I installed the betterbatterystats and its the media scanner services. I have had problems with my sd card, and might be related. I may need to reformat it.
  4. #4
    Default
    Awesome I'm glad to hear that helped. Sounds like it might be an easy fix. Glad I could be of some assistance.
  5. #5
    gdanonym's Avatar
    Posts
    Global Posts
    388 Global Posts
    It's pretty easy.
    Click on the running time graph and see if the phone is getting into the sleep mode.
    It's probably not.
    Run CPU spy to make sure of this in about a minute of screen off.
    Reboot the phone and try the CPU spy test again. If it's still not going into the deep sleep, check the current processen in settings, applications. One of these must be the cause or one of the widgets.
    Remove the apps one by one and see if it helped.
    Once found you can reinstall the good apps. Keep monitoring this once in a while.
    Are you convinced it's OK, you can remove CPU spy and just use the battery monitor to check it.
  1. Replies: 2
    Last Post: 12-05-2013, 06:58 AM
  2. How to choose a tablet for a 9 years old son?
    By ninolimoni in forum General Help and How To
    Last Post: 12-04-2013, 07:40 PM
  3. GAPPS force-closing constantly after 4.4 KitKat update.
    By abraham the grey in forum Google Nexus 4
    Last Post: 12-04-2013, 05:50 AM
  4. samsung ace unable to find music and picture
    By Ioan Apetrei in forum Samsung Galaxy Ace
    Last Post: 12-03-2013, 06:32 AM
  5. nexus 4 drains faster then it charges when plugged...
    By bagou01 in forum Android 4.4 KitKat
    Last Post: 12-03-2013, 03:58 AM
B
