Page 6 of 6 FirstFirst ... 3456
Results 126 to 132 of 132
Like Tree8Likes
  1. #126
    kaide23's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Galaxy Note 2 - Massive battery drain after 4.3 update
    Quote Originally Posted by kaide23 View Post
    I have done all the steps but my battery keep draining also... First time to root my phone but success just really dont know why...
    Attached picture for your guys reference: please help, this is the phone my wife bought for me and it is not helping me to work since the update... thanks in advance...
  2. #127
    Malum Regina's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I am experiencing the same issue. Android System and Android OS are sucking the life out of my battery.... I even bought a new battery, and the problem got worse. In fact, every day it gets worse. Now, it takes my phone 10 hours to completely charge. All apps are closed, nothing I can find is running .... I've had my phone for 2 years, and I think this is Samsung's way of forcing me to upgrade... Dumb smart phones....
  3. #128
    Sahana M's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Yes, the same issue even I am facing.. and it is terrible. Please help
  4. #129
    DWooderson's Avatar
    Posts
    Global Posts
    103 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Last week, my battery started draining from full to completely empty (phone turns off) in about 10 hours with only moderate usage. I can't even make it through a workday now, and I used to be able to go all day and all night?! I tried everything I could find online, to no avail.
    Battery consumption (top 4 items combine for 70%):
    • Google Play Services 30%
    • Gmail 19%
    • Screen 12%
    • Android OS 8%
    So last night, I did a factory wipe, re-rooted, and spent hours configuring it like I like it. I also disabled the 4.4 OTA update (again). I updated a few key apps, like Gmail and Google Maps, but I am not planning to update any other apps for now, until I see whether my battery life has improved or not.
  5. #130
    Ramanathan Moorthy's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I agree. The turning off google location settings did the trick. Very thankful to the tip. Also, I downloaded mapquest to use GPS instead of giving access to google location settings when I had to use maps. It is not as good as google maps but not too bad either. I also have disabled things like Deezer, knox and quite a lot of stuff that got into my mobile after updating from 4.1.2 to 4.3 versions of android.
  6. #131
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I agree. The turning off google location settings did the trick. Very thankful to the tip. Also, I downloaded mapquest to use GPS instead of giving access to google location settings when I had to use maps. It is not as good as google maps but not too bad either. I also have disabled things like Deezer, knox and quite a lot of stuff that got into my mobile after updating from 4.1.2 to 4.3 versions of android. I did do a factory reset through Samsung Kies 3.0 but had to do it only once (which was many months ago). Of late, I have managed to touch 3 days 1 hour with 26% remaining but I had turned off internet access in all ways for few hours on each of the days in between, when I was sleeping... My worry now is whether to go for the 4.4.2 update or not? Kindly reply please if possible. Many thanks.
  7. #132
    elcherkaoui's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by flashsexington2 View Post
    Hi, I had the same problem after 4.3 update. I did not want to do a factory, and going from a lot of posts this does not work anyway. I also didn't want to turn off a lot of processes I previously had running. I just wanted the same level of performance as before. After doing a little research I have come believe it is a battery calibration issue. This worked for me. Charge your phone to 100%, goto keypad, type in *#0228#. This will take you to a battery status screen. Press quick start at the bottom of the screen. Your screen will go blank for a few seconds. Press the home key. Your battery percentage should have dropped. Charge to 100% and repeat the process. After a few times the drop should be negligible. Allow the battery to completely discharge and repeat. Hope this helps. Good luck.
  1. Replies: 15
    Last Post: 06-04-2016, 10:12 PM
  2. Replies: 3
    Last Post: 02-01-2015, 07:52 PM
  3. Battery running down too fast
    By isabel95 in forum Verizon Galaxy S3
    Last Post: 01-06-2014, 07:30 PM
  4. Galaxy S3 - Very very strange battery problem!
    By babakk1 in forum Samsung Galaxy S3
    Last Post: 01-06-2014, 03:38 PM
  5. battery problem
    By predator1o1 in forum Samsung Galaxy S3 I9300
    Last Post: 01-06-2014, 01:28 PM
