1. Duard's Avatar
    As measured by the "My Drives" app my space in /system (1.72gb total) is 93.3% full - it was about 80% before the update. On a prior phone (Infuse 4G) I let the /system space get full and could not recover without a factory reset so I want to deal with the situation before it gets worse.
    About half of the space is apparently .apk's - but I deleted a bunch of programs without making a dent in /system.
    I believe that I could root the phone and delete some of the bloatware - for example, speech-to-text seems to use a lot of room but I will never use it. But I'm looking forward to the 4.4 update, and I believe there's a significant risk that the update will not load if I have removed the wrong bloatware.
    Any suggestions on freeing up some space on /system?
    01-24-2014 08:38 PM
  2. FutureKix's Avatar
    First, I would not recommend rooting just for deleting bloatware, because like you said, 4.4 is on it's way. That being said, I would try deleting any cache or app data on the system apps you don't use, and disabling them so they don't grow again. I know the S4 can disable built in apps, and I believe the Note 2 can as well. Not much else I can say, hope this helps! Good luck!
    01-27-2014 12:44 PM
  1. Replace AccuWeather, set degrees to F (not C)?
    By BlackAudiA5 in forum General Help and How To
    Last Post: 04-01-2017, 03:03 PM
  2. Returning to stock ROM [Sprint] on Cyanogenmod 11 to Ting Mobile
    By Pablo Escobar1 in forum Sprint Galaxy S III Rooting, ROM's, and Hack's
    Last Post: 01-29-2014, 08:27 PM
  3. Please Help, Battery drain after repair
    By Jay_876 in forum AT&T Samsung Galaxy S4
    Last Post: 01-28-2014, 10:21 AM
  4. Moving on from Meenova to Leef
    By Tom in Bristol in forum Moto X (2013)
    Last Post: 01-25-2014, 06:29 PM
  5. How to stop data from being used?
    By xonq in forum Samsung Galaxy S4
    Last Post: 01-24-2014, 08:26 PM
