Results 1 to 2 of 2
    Default 4.3 wifi issue
    I just upgraded my AT&T Note 2 to 4.3 and now the phone will not connect to wifi when it has 4G LTE service. It will try to connect to wifi but then just says "turned off" underneath the network it is trying to connect to.
    To use wifi I have to turn off the mobile data network manually.
    How do I fix this?
  2. #2
    Default Re: 4.3 wifi issue
    Have you checked your connection optimizer? I forget what Samsung calls it exactly but its your Settings. If enabled it will select the best method of connection at that point in time.
    Most of the time that would be wifi but if the mobile signal is stronger it will default to that.
    Sent from my HTCONE using AC Forums mobile app
  1. WiFi Calling
    By scag21 in forum Sony Xperia Z1s
    Last Post: 02-25-2014, 04:54 PM
  2. Active Notification issue after system update
    By Kaymak in forum Moto X (2013)
    Last Post: 02-06-2014, 08:21 AM
  3. Nexus 7 32GB on Groupon (Wifi or 4G)
    By VDub2174 in forum Google Nexus 7 Tablet (2012)
    Last Post: 02-05-2014, 07:24 PM
  4. Another VZW S3 wifi issue
    By pjcruiser in forum Verizon Galaxy S3
    Last Post: 02-05-2014, 07:23 PM
  5. Certain apps/games only via WiFi?
    By Doggu53 in forum General Help and How To
    Last Post: 02-05-2014, 01:53 PM
