1. fade2black101's Avatar
    Hi
    Since upgrading to 4.3 on my Note Ii, I have noticed that when the pebble is connected to my phone, it causes the sound quality to diminish significantly when using my Bluebuds X bluetooth earphones. Sort of like resembling a low bitrate MP3.
    This doesn't seem to be a problem on the Nexus 4 or on the 4.1.2 version of Android that was on my Note II before. It feels to me that when the pebble is connected, the buggy and broken bluetooth drivers switch to a low bitpool version of A2DP which sound like complete and utter cack. It reverts back to better quality (perhaps APT-X) when the pebble is disconnected.
    I was wondering if anyone has any suggestions, as it is a bit of a dealbreaker for me and, quite frankly, a massive massive pain in the *** which is prohibiting me enjoying the phone & pebble properly. The only thing stopping me switching to a different phone like the HTC One or Xperia Compact is that I can't be sure the bluetooth doesn't also have the same problem on those, as they are also on 4.3.
    Thank you for any help.
    02-20-2014 01:06 PM
  2. fade2black101's Avatar
    Just tested this on a stock HTC One (also on 4.3) and it has the exact same issue. Seems to be a problem with Android itself. I find it hard to believe that this problem isn't widespread on 4.3. Will test it on a Note 3 tomorrow.
    I hope the Kit Kat update gets a move on...
    02-20-2014 06:10 PM
  1. Replies: 1
    Last Post: 02-25-2014, 06:01 PM
  2. Battery life with Pebble Smartwatch
    By charlee08 in forum Moto X (2013)
    Last Post: 02-21-2014, 08:52 PM
  3. Music not sound on SD card using Walkman app
    By Flipcjl in forum Sony Xperia Z1
    Last Post: 02-20-2014, 12:59 PM
  4. Replies: 0
    Last Post: 02-19-2014, 04:47 PM
  5. Lost Cell Signal / Dead Spot Causes DNA to Power Down
    By yankswinagain in forum Verizon Droid DNA
    Last Post: 02-18-2014, 12:12 PM
