S sodaorange New member Mar 31, 2014 1 0 0 Visit site Mar 31, 2014 #1 My quad band GSM is 850/900/1800/1900 mhz edge/gprs/gsm, tri band UMTS 850/1900/2100 MHz HSPA and dual band 700 and 1700 MHz LTE networks. SGH-I317M Version 4.3
srkmagnus Retired Moderator May 23, 2010 13,434 210 0 Visit site Apr 4, 2014 #2 Welcome to the forums! Short answer is that you can't. The radio frequency is built into the hardware of the device (antenna). So without that specific hardware to support the frequency you want, there is no way to change it.
dpham00 Moderator Team VP Moderator Apr 23, 2011 30,108 200 63 Visit site Apr 9, 2014 #3 Are you sure it doesn't support 1700/2100? I saw here that it does http://pdadb.net/index.php?m=specs&id=4014&c=samsung_sgh-i317m_galaxy_note_ii_lte dpham00, Android Central Moderator Sent from my Verizon Samsung Galaxy Note 3 via Tapatalk Pro
