Results 1 to 9 of 9
Like Tree1Likes
  • 1 Post By dbarnes2270
    JnEricsonx's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Better case+screen for Note 2 than Otterbox?
    I love my Otterbox case, it makes me feel secure, but god the screen protector collects scratches, dust, and crap like you wouldn't believe, despite the only thing touching it 90% of the time is the S-pen and I keep it in the belt holster IN my pocket. Now, I've been told to heat out the glue of the screen protector and apply another one, but is there a case+screen combo like Otterbox out there?
  2. #2
    dbarnes2270's Avatar
    Posts
    Global Posts
    46 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Better case+screen for Note 2 than Otterbox?
    I'm a fan of the Seidio Convert case. It ships with a screen protector that is separate from the case. The holster is also designed to connect to a bike or car mount that you can purchase separately.
    tube517 likes this.
  3. #3
    tube517's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Decks Reloaded,RebelROM
    Anytime you have a plastic screen like that, it will collect dust.
    I am suprised Ballistic didn't make a case for this phone.
  4. #4
    amcjavelinsst's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    At first the under screen stuff bugged me
    then I just clean it
    It gets easier to take off the more you do it & it does not the long
    I don't clean it as much now as used to it
    easy fix for such a strong case & the protection it offers
    Would rather take the 1 minute to clean than go another case
    Sent from my GT-N7105T using AC Forums mobile app
    JnEricsonx's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Well, what do you use to clean it off well? I mean, Even with just my finger and the s-pen there's scratches, on the protector obviously, not the phone. I just wish there was a more complete seal. I might bite the bullet and just get a regular case with a seperate screen protector. How's the UAG type stuff?
  6. #6
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I got some gel tube of cleaner when I first got the phone at end 2012 or Start 2013 & its still going
    just a window cleaner works well & is probably what I use most
    other times just a spit on my fingers & rub
    most is just dust after all
    use a microfibre or any rag tissue or tee shirt for the outside of the screen that gets all the S-pen marks on it
    they are not scratches per se, more like removable markings
    All easy peasy really
    Also in time your tolerance to the dust may increase so it wont bother you as much, thats what helped me to get over it, so now when I do notice it it really does need a clean & done quite quick
    A bit of elbow grease on the outside screen protector does wonders
  7. #7
    lvdukerider's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    What I did was install a screen protector, trimmed to fit the clear face of the Otterbox, covering the hole over the button. Thats where all the dust gets in and the button works fine covered by a screen protector. I dont get why Otter box puts a hole there for the button its not necessary and compromises a otherwise fine case. Rubber caps for the camera and S pen would be a nice touch also.
  8. #8
    tube517's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    I use a microfiber cloth slightly damp and then dry it off with a dry part of the microfiber.
    Some people just take the plastic cover off and put their own screen protector (see post above). I may try that one day.
  9. #9
    Trent9810's Avatar
    Posts
    Global Posts
    105 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    UAG cases are my pick!
  1. Galaxy S5: Turn off screen wake for SMS?
    By Westifire in forum Samsung Galaxy S5
    Last Post: 04-26-2014, 12:06 AM
  2. S Note & Evernote Login Problems
    By toastayy in forum Samsung Galaxy Note 8.0
    Last Post: 04-24-2014, 09:52 PM
  3. Replies: 0
    Last Post: 04-24-2014, 08:53 PM
