Results 1 to 3 of 3
    badmaash's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Exclamation Auto starting note 2 4.4.2
    Hi, I have NOTE 2 INTERNATIONAL VERSION. I am from India and have got the latest stock 4.4.2 update. Phone is rooted and KNOX removed.
    The problem is suddenly whatsapp has started consuming too much battery over 50% as per battery stats. My phone battery drains below critical levels and right now it is 0% and does not boot. When i plug it to the charger the phone immediately boots but because of insufficient battery shuts off and then again restarts and so on. The phone never gets charges cause of this.
    I will charge the battery putting it in another NOTE 2 but I wish to understand why I cannot shut down my phone. Even on full charge the phone if I shut it down does not shut down but restarts never completely staying switched off.
    Please help.
    Thank you.
  2. #2
    Kelly Burby's Avatar
    Banned
    Posts
    Global Posts
    706 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Auto starting note 2 4.4.2
    Quote Originally Posted by badmaash View Post
    Please help.
    Thank you.
    Well, it seems much more weird to me are you sure the battery of your device is good enough to hold the charge ?? I think the problem is with the battery because if the device doesn't shows up there is nothing that we can suggest you in order to get out from this mess.... I would say try going to the nearest customer support for fixing it up.
    badmaash's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    The phone switches off now after factory reset but when its switched off and I plug in the charger it switches on automatically. Before on 4.1.2 there used to be charging sign and battery on the screen for a while and phone used to charge without booting up but now instead it boots up immediately.
  1. Lock screen widget for Notes
    By Oliver Buxton in forum Android Apps
    Last Post: 06-04-2014, 05:55 AM
  2. Should I keep with the note 3?
    By selena650 in forum Samsung Galaxy Note 3
    Last Post: 06-01-2014, 02:02 AM
  3. HTC M8 and Note 3 Verizon SIM
    By Ragan Evans in forum HTC One M8
    Last Post: 05-09-2014, 04:43 PM
  4. HTC M8 and NOTE 3
    By Ragan Evans in forum Verizon
    Last Post: 05-09-2014, 01:37 PM
  5. Random error on my Samsung Galaxy Note 3
    By enduser2941 in forum Samsung Galaxy Note 3 Rooting, ROMs, & Hacks
    Last Post: 05-08-2014, 09:55 PM
