Results 1 to 5 of 5
    Default Yet another problem with my phone since KitKat
    The last few phone calls I have had to toggle off the speaker and then toggle it back on in order to hear the person on the other end at normal speaker volume. I don't recall this happening on 4.3
    Sent from my SCH-I605 using AC Forums mobile app
  2. #2
    srkmagnus's Avatar
    Posts
    Global Posts
    13,715 Global Posts
    Carrier
    Stock 4.4 (KitKat)
    Default Re: Yet another problem with my phone since KitKat
    Quote Originally Posted by 1812dave View Post
    Since receiving the update, have you performed a factory reset? If not, do a reset and see if that clears up any of the bugs you are experiencing. Be sure to backup your data and sync accounts.
    I found a solution to my problem that is more elegant than the app that I had been using for many months. Auto speaker by Techoworx is what I just installed
  4. #4
    good info,found a solution to my problem that is more elegant than the app that I had been using for many months.thanks
    Quote Originally Posted by tegorizefod View Post
    good info,found a solution to my problem that is more elegant than the app that I had been using for many months.thankshttp://www.yinlu.us/e.gif
    I'm sorry to report that that app stopped working shortly after I installed it and I tried a bunch of other apps, probably at least six or more and none of them worked when my Gear 2 watch has Bluetooth enabled to the note , so I reinstalled my original app and it has been working okay since yesterday
  1. Samsung 10.1 Note Calendar Sync Problem
    By Guvnes in forum Ask a Question
    Last Post: 09-28-2014, 12:33 AM
  2. Help! Battery drain fast since Android updates
    By CeruleanBlue58 in forum Google Nexus 4
    Last Post: 07-06-2014, 10:38 AM
  3. update problem
    By Venkataraman AP in forum Android 4.4 KitKat
    Last Post: 06-28-2014, 05:44 PM
  4. MY phone says it's charging when it's not
    Last Post: 06-28-2014, 02:57 PM
  5. VZ Activations back yet?
    By aweber1nj in forum Verizon
    Last Post: 06-28-2014, 11:29 AM
