Galaxy Note 3 echo problem solved
t9rfbb
4
I bought my Samsung Galaxy Note 3 SM-N900W8 from Mobilicity (not a T-Mobile) and have had it for a couple of weeks. I wanted to put a hard case on it before I left the mall but couldn't find anything like an Otter or other armored case. So, at Pacific Mall I bought an inexpensive ($15) UAGIDS case which has a soft plastic liner and hard plastic outer band. I added a clip-on leather belt pouch (another $15) which holds the phone in its UAGIDS case. Altogether this gives pretty good protection with easy access to the phone and a convenient means to carry it.
The problem:
The phone worked fine until I put the case on it. After installing the phone in the case the caller at the other end was hearing a very major echo. It did not matter which side initiated the call.
The solution:
After a lot of fruitless research on the Internet (many others complaining of the same or similar problem) I found nothing that would help me. So I decided to go back to basics and examine the phone and case carefully. I found two instances where the case was deficient.
1st, there was no aperture (opening) in the case by the speaker to let sound out. A dremel tool fixed that. Cutting through the soft inner liner was much more difficult than carving the hard outer band.
2nd, there was no aperture in the case for the tiny anti-echo mic located on the bottom edge of the phone, just to the left of the big multipurpose jack (where you plug in the funky USB cord). Drilling a 1/8" hole in the hard outer band and using a leather hole punch on the soft inner liner fixed that.
Putting the phone back into the case and testing showed that the echo problem was completely gone. Problem solved!
I suggest you check any case you buy for a phone and be sure it was engineered for that phone and has all the necessary ports the phone needs to function properly. Glad I didn't pay a lot for the case. Hope that when a good quality hard case becomes available I won't have to worry about engineering problems ;-)
One other mod I did to the case was to enlarge the port in the case from which one retrieves the pen. I need more room for my large fingers.
Incidentally, contrary to advice on the WEB disabling or enabling the Noise reduction had no effect on the original problem, thats as it should be because that is intended to deal with background noise in the location where you are using the phone.
An afterthought is that there are two microphones, one on the top edge and one on the bottom edge of the phone. The apertures in the phone for these microphones is extremely small, not more than 1/32 of an inch or about .75mm. It would not take much of a particle of dirt or something similar to block a microphone and cause no end of havoc. Cleaning these apertures would be difficult and poking them with something would be very risky at best.
I have the note 3, all holes are clear on case "speck" and still have an echo. Echo goes away when I use Bluetooth or speaker phone or ear phones... but without anything but the phone, in the case or out of the case, I have a bad echo on the other end. I don't hear the echo. And the answer is????? Please!!!
I had this problem after transferring my phone's guts to a new LCD, frame and digitizer after I cracked my old screen. I reused the mic and speaker from the old phone. The mic and speaker are held down with tape and I guess the tape wasn't holding them in place. I ordered a new mic (comes with the charging flex cable) and ear speaker (comes with the heaphone jack) and replaced them. Now my echo is fixed. Thought I'd throw this out there for people that are getting echo after working on their Galaxy Note 3s.
Hi thanks for the help diesavagenation, I have this same problem on my galaxy s5. I am wondering if it was difficult to replace the mic?
I have an echo of my voice on my note 4. It's hard to talk when I hear myself in a 2 second delay. Any fixes? I love the phone except for this, it's driving me nuts & I am considering returning it
Greatest news for all of you to kill echo problems being observed at caller side, will be resolved in seconds......................... Promise to all of you that my research will work 100% in few seconds.... Echo problem at caller side will be eliminated completely...
So if you interested ... Just reply me that you are 100% interested in my suggestion then i will reveal my research.
i need ur suggestion but i have alcatel idol 3 from koodo candian carrier and after 5.02 update lolipop it has echo. it came with 5.01. The phone ear piece , headphone with mic and speaker all echo but speaker is the worst bz it is too loud and i can talk . it only echo to callers on other side not me.
LEricG
