HELP!!!How to delete Sent from Samsung mobile e-mail signature on Rogers/ Fido Note 3??
Bruce-YVR
16
Guys? just got the Note 3. Love it? except I can't get rid of the e-mail signature!!! Sent from Samsung Mobile.
Please tell me there is a way!!!!!!!!!!
Thanks
Bruce
UJ95x
Retired Ambassador
Aug 26, 2013
9,337
Hi? I am using Gmail and Samsung email for work? would love to get rid of the signature? had a Note 2 and was ok? Thanks for your help!
For G-Mail, go to settings, select the account you're using and erase the signature.
Not sure about the stock e-mail app, but I'm sure it's something similar. Let me get someone to help you with that :)
Sent from my Galaxy S4 running SlimKat 4.4.2
May 19, 2014
199
You are having trouble with both?
In your Gmail app, under settings, you should be able to clear out the signature. I'd imagine there is a similar setting on the Samsung. I do not have a Samsung device, so I can not be certain. I have no signature on my Gmail.
Bruce-YVR
16
Thanks very much… I tried and google for info but no luck… I am hoping I can get rid of the Sent from Samsung Mobile… thanks again for your help...
UJ95x
Retired Ambassador
Aug 26, 2013
9,337
Thanks? Gmail ok? just Samsung e-mail? want to get rid of that signature
Just checked out someone's S4...it's exactly the same. Tap the menu button, then select the account and turn off your signature.
jpr
1,700
48
Thanks
Bruce
I have a different model Note 3 than yours so may not be able to help. But when you go to your individual email account settings, is there not a Signature option on the second line right under the Sync settings line?
Do your settings look different than this screenshot?
Bruce-YVR
16
Yes!… Thanks… got it…
Now the next question, can I customize a signature on the samsung stock e-mail app??
Thanks
Bruce-YVR
16
Yes… i got it ( again ) Thanks very much…
It was easy but I just didn't tap on the account to drill down further… duhhhhh me :)
Thanks for all your help!!
HFL
Active member
May 6, 2014
33
u can clear it.. u dont need to turn it off...
steps:
1.Go to Email app
2.slide from left to right (Menu)
3.Mange Accounts
4. Signature , then it let you add it. u can chance to whatever u wanna or leave it empty..
so no reason to turn off..
app the menu button, then select the account and turn off your signature.
Kaisu
Hi guys.
It is easy to remove the signature from own gmails, but for some reason the "sent from Samsung" signature appears, when I reply to another e-mail. Is there any way to remove that one?
And yes, it is long ago, when I changed the signature and shut it off. I have shut down the phone sevral times since then :)
Kaisu
samyblaze
