Results 1 to 15 of 15
    Bruce-YVR's Avatar
    Posts
    Global Posts
    17 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default HELP!!!How to delete Sent from Samsung mobile e-mail signature on Rogers/ Fido Note 3??
    Guys just got the Note 3. Love it except I can't get rid of the e-mail signature!!! Sent from Samsung Mobile.
    Please tell me there is a way!!!!!!!!!!
    Thanks
    Bruce
  2. #2
    UJ95x's Avatar
    Retired Ambassador
    Posts
    Global Posts
    10,442 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock 6.0.1
    Default Re: HELP!!!How to delete Sent from Samsung mobile e-mail signature on Rogers/ Fido Note 3??
    Which e-mail app are you using?
    Bruce-YVR's Avatar
    Posts
    Global Posts
    17 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by UJ95x View Post
    Hi… I am using Gmail and Samsung email for work… would love to get rid of the signature… had a Note 2 and was ok… Thanks for your help!
  4. #4
    UJ95x's Avatar
    Retired Ambassador
    Posts
    Global Posts
    10,442 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock 6.0.1
    Quote Originally Posted by Bruce-YVR View Post
    Hi I am using Gmail and Samsung email for work would love to get rid of the signature had a Note 2 and was ok Thanks for your help!
    For G-Mail, go to settings, select the account you're using and erase the signature.
    Not sure about the stock e-mail app, but I'm sure it's something similar. Let me get someone to help you with that
    Sent from my Galaxy S4 running SlimKat 4.4.2
  5. #5
    vinnie_boombhats's Avatar
    Banned
    Posts
    Global Posts
    205 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    You are having trouble with both?
    In your Gmail app, under settings, you should be able to clear out the signature. I'd imagine there is a similar setting on the Samsung. I do not have a Samsung device, so I can not be certain. I have no signature on my Gmail.
    Bruce-YVR's Avatar
    Posts
    Global Posts
    17 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thanks very much… I tried and google for info but no luck… I am hoping I can get rid of the Sent from Samsung Mobile… thanks again for your help...
    Bruce-YVR's Avatar
    Posts
    Global Posts
    17 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thanks… Gmail ok… just Samsung e-mail… want to get rid of that signature
  8. #8
    UJ95x's Avatar
    Retired Ambassador
    Posts
    Global Posts
    10,442 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock 6.0.1
    Thanks Gmail ok just Samsung e-mail want to get rid of that signature
    Just checked out someone's S4...it's exactly the same. Tap the menu button, then select the account and turn off your signature.
  9. #9
    jpr
    jpr is offline
    jpr's Avatar
    Posts
    Global Posts
    1,702 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thanks
    Bruce
    I have a different model Note 3 than yours so may not be able to help. But when you go to your individual email account settings, is there not a Signature option on the second line right under the Sync settings line?
    Do your settings look different than this screenshot?
  10. Thread Author  Thread Author    #10
    Bruce-YVR's Avatar
    Posts
    Global Posts
    17 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Yes!… Thanks… got it…
    Now the next question, can I customize a signature on the samsung stock e-mail app??
    Thanks
  11. #11
    jpr
    jpr is offline
    jpr's Avatar
    Posts
    Global Posts
    1,702 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Just click on the signature setting.
  12. Thread Author  Thread Author    #12
    Bruce-YVR's Avatar
    Posts
    Global Posts
    17 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Yes… i got it ( again ) Thanks very much…
    It was easy but I just didn't tap on the account to drill down further… duhhhhh me :-)
    Thanks for all your help!!
  13. #13
    UJ95x's Avatar
    Retired Ambassador
    Posts
    Global Posts
    10,442 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock 6.0.1
    Yes i got it ( again ) Thanks very much
    It was easy but I just didn't tap on the account to drill down further duhhhhh me :-)
    No problem.
    See you around the forums
  14. #14
    HFL
    HFL is offline
    HFL's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    u can clear it.. u dont need to turn it off...
    steps:
    1.Go to Email app
    2.slide from left to right (Menu)
    3.Mange Accounts
    4. Signature , then it let you add it. u can chance to whatever u wanna or leave it empty..
    so no reason to turn off..
    app the menu button, then select the account and turn off your signature.
  15. #15
    Kaisu's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Hi guys.
    It is easy to remove the signature from own gmails, but for some reason the "sent from Samsung" signature appears, when I reply to another e-mail. Is there any way to remove that one?
    And yes, it is long ago, when I changed the signature and shut it off. I have shut down the phone sevral times since then :-)
    Kaisu
  1. How long does LG repair services take?
    By Walkingbad in forum LG Optimus Series
    Last Post: 06-13-2016, 06:28 AM
  2. Sent in rooted phone to Samsung Repair Center....
    By JMoney973 in forum Sprint Samsung Galaxy S4
    Last Post: 05-27-2014, 01:08 PM
  3. New installs defaulting to internal memory
    By Chris Tietz in forum General Help and How To
    Last Post: 05-26-2014, 12:47 PM
  4. Music not being played while from SD card.
    By CynicalLoner in forum Samsung Galaxy S5
    Last Post: 05-23-2014, 10:23 PM
  5. Lost OS on accident! NEED HELP
    By footballguy108 in forum HTC One M8 Rooting, ROMs, & Hacks
    Last Post: 05-22-2014, 02:50 AM
