Results 1 to 2 of 2
    Default HELP! Note 3 Stuck in Bootloop
    Ok so ive rooted my Note 3 n9005, installed twrp, flashed x note and gone through its setup process. Then when i rebooted the phone its stuck in a boot loop. It won't even boot into recovery.
    So I headed over to Sam Mobile to download the stock firmware and it wont download correctly, it gets to around 40% then says download done but when i go to the zip file there nothing inside it to extract.
    Any ideas what I can do now? I'm stuck as i've never been in a position where i couldn't download the stock firmware, i've got my twrp backup but im assuming i cant flash that using Odin?
    If anyone can give advice asap I would be very grateful, kind of freaking out a bit!
  2. #2
    NoNexus's Avatar
    Posts
    Global Posts
    309 Global Posts
    Default Re: HELP! Note 3 Stuck in Bootloop
    Download ODin
    Download an Odin stock image
    Put your phone in download mode
    flash the Odin image.
    That is the short answer. You are in a softbrick. Not a big deal. Go over to XDA, look for your phone on your carrier, and follow the instruction on how to return to stock.
    Don't panic.
  1. Need help returning to stock to receive updates again
    Last Post: 03-31-2015, 08:08 PM
  2. camera help
    By pocketsrn in forum HTC One Max
    Last Post: 07-13-2014, 08:58 PM
  3. I'm still running Android Jelly Bean 4.3 on my Note 10.1 2014...
    By Diamant Belallari in forum Samsung Galaxy Note 10.1 (2014)
    Last Post: 07-11-2014, 08:30 AM
  4. Galaxy s4 screen goes off and on!!help
    Last Post: 07-08-2014, 08:47 PM
  5. Root Help Sprint Galaxy Mega 6.3 sph-l600
    By Kgoodson1017 in forum Ask a Question
    Last Post: 07-06-2014, 05:40 PM
