Page 1 of 5 1234 ... LastLast
Results 1 to 25 of 110
Like Tree31Likes
    Default Note 3 - FM Radio tuner???
    It was my understanding the new Samsung phones were going to have the FM tuner enabled again. The Galaxy S5 is supposed to have an FM tuner. Does anyone know if the Note 3 has one or not?
    Thanks!
    Thanked by:
    boudicca00 likes this.
  2. #2
    Raptor007's Avatar
    Posts
    Global Posts
    4,847 Global Posts
    ROM
    Stock .4.1.1
    Default Re: Note 3 - FM Radio tuner???
    So if it doesn't isn't there an app for that. But honestly when was the last time you listened to terrestrial radio on you phone?
    chustle925 likes this.
    It would be nice to do something on the Note without being on WiFi or a Cell network.
    Listening to a nice radio station while enjoying the creativity of the Note, that would be bliss!
    Iso10 and diasmall like this.
  4. #4
    I hope they have one on there. Its nice to use an app but apps dont always let you listen to sports games. I like my local announcers during the eagles games an the apps dont always stream the games
    ttrain68 likes this.
  5. #5
    Raptor007's Avatar
    Posts
    Global Posts
    4,847 Global Posts
    ROM
    Stock .4.1.1
    You are right, it was just something I never used on my phone but there must be a radio app you can d/l from the play store.
  6. #6
    Quote Originally Posted by Raptor007 View Post
    If it doesn't have fm radio support, then no app could add it, like on my Verizon Samsung Galaxy Note II. Yes, you can use Internet radio, but it isn't the same for me.
    Sent from my Verizon Samsung Galaxy Note II via Tapatalk 4
    Thanked by:
    21stNow likes this.
  7. #7
    NoNexus's Avatar
    Posts
    Global Posts
    142 Global Posts
    It is better. Tune in pro is great for listening to everything especially games. Check it out.
    soulstlr likes this.
  8. #8
    Raptor007's Avatar
    Posts
    Global Posts
    4,847 Global Posts
    ROM
    Stock .4.1.1
    Quote Originally Posted by dpham00 View Post
    Sorry I didn't realize that, I never used the built in FM tuner's on other phones. Too bad.
  9. #9
    Quote Originally Posted by NoNexus View Post
    I have used tune in radio pro, Spotify, Pandora, rdio, and slacker. While they serve their purpose, I still like to have a fm radio, one that doesn't require data, because sometimes I am at overloaded towers and data speed is very slow.
  10. #10
    Raptor007's Avatar
    Posts
    Global Posts
    4,847 Global Posts
    ROM
    Stock .4.1.1
    I am not saying it will or won't work but I did a quick Google search and found a number of Android apps that are FM Tuner apps. I would say when the phone hits you can always d/l and test it out. Heck I will try it out too.
  11. #11
    The fitness center I go to has FM to listen to the TV audio they have. Otherwise, TV with no sound is not too appealing.
  12. #12
    mssca's Avatar
    Posts
    Global Posts
    2,987 Global Posts
    ROM
    CM 10.2
    It has the hardware support already built in. Hopefully a Mod OS will unlock it if the FM antenna files are locked by default.
    http://sanuja.com | SGH-I747M
  13. #13
    gavinfabl's Avatar
    Posts
    Global Posts
    51 Global Posts
    FM radio will never work. Apart from apps there is no way.
    Or buy Sony that has FM radio..
    Sent from my Nexus 7 using Tapatalk 4
  14. #14
    Would be good to have the option but not a fan of using the headset as the aerial. Always found them to be poor at play picking up a signal.
    The radio stations suck in the UK anyways. Full of simon cowells manufactures artists.
    Sent via my mobile communications device.
    Samsung Galaxy Note 3 Running Stock KitKat 4.4.2
  15. Thread Author  Thread Author    #15
    LG G2 has a radio, as well as the Sony Z1.
  16. #16
    Never had a FM radio since owning a Samsung device but all my HTC devices had one.
  17. #17
    I love the FM tuner on my Motorola Photon and use it often. I am getting a Note 3 the second I can but I would miss the tuner if the Note comes without.
  18. #18
    GtoJon's Avatar
    Posts
    ROM
    Stock Note 2
    Specs say my the Note 2 has the same FM tuner as the Note 3 .... none of the apps for tuners work to enable the tuner. It has been blocked & am sure the Note 3 will have the same block on Verizon! What's up with that? I had a Thunderbolt before the S3 & FM worked great! Hope somebody cracks it!
    Cheers, Jon
  19. #19
    For the phones with a functioning FM tuner, how good is the reception, particularly indoors? I own a small MP3 player that I use in the gym. It has an FM tuner, but it's worthless indoors.
  20. #20
    GtoJon's Avatar
    Posts
    ROM
    Stock Note 2
    Wink Re: Note 3 - FM Radio tuner???
    Quote Originally Posted by Simon_y7 View Post
    My Thunderbolt worked great indoors or out !
    Cheers, Jon
    maggybjork likes this.
  21. #21
    Raptor007's Avatar
    Posts
    Global Posts
    4,847 Global Posts
    ROM
    Stock .4.1.1
    I forgot about the Thunderbolt having the FM tuner, I had that for a while, until I couldn't deal with the battery life anymore.
  22. #22
    Never had it either. I hate fm in my car, thats why I got Sirius/XM. I sure dont want it on my phone. I use the Sirius/XM app, and tune in radio to find a specific station else where that has a short term program of interest. And thats rare.
  23. #23
    GtoJon's Avatar
    Posts
    ROM
    Stock Note 2
    My interest in FM is for weather reports .... I go out in the wilderness a lot with no option for data .... FM isn't that great, but have been able to get weather from FM when data is definitely not an option!
    Cheers, Jon
    Have Note 2 & ordered Verizon 32gb/64gb Note 3 in white
  24. #24
    According to GSMArena, Note 3 WILL have FM Stereo radio.
  25. #25
    I would want to use the FM tuner for listening to sports broadcast during a game. I was at a Dodgers game and trying to stream an online feed was impossible. There were so many competing cell phones you couldn't get a reliable connection and if you did it was delayed and kept having to wait for buffer. It also chewed up battery very quickly.
  1. Got a used Note II from Ebay to use with Straight Talk
    By Medicineman in forum AT&T Galaxy Note 2
    Last Post: 01-25-2014, 02:22 PM
  2. Note 3 Screen - Pentile?
    By the_stig#WN in forum Samsung Galaxy Note 3
    Last Post: 09-11-2013, 11:37 AM
  3. Note 2 coming in tomorrow, a few questions
    By Chad H in forum AT&T Galaxy Note 2
    Last Post: 09-08-2013, 02:09 PM
  4. Any news about note3 software update for note 2
    By jeno27 in forum Samsung Galaxy Note 2
    Last Post: 09-06-2013, 09:35 AM
  5. Replies: 2
    Last Post: 09-04-2013, 07:27 PM
B
