Will a US phone work with LTE, HSPA+ and 3G in the UK?
Android Rage
16
I want to buy the unlocked Samsung Galaxy Note 3 from Verizon Wireless on the $699.99 plan and bring it over to the UK. Unlocking is not a problem because if the handset doesn't come unlocked, I can get it unlocked. My question is whether the phone will work with LTE, HSPA+ and 3G in the UK. Here are the network specifications directly off of the Note 3 page on Verizon Wireless' website:
CDMA Data ? 1x and EVDO Rev0/RevA
LTE: B13 (700MHz)
Global Ready (GSM/EDGE: 850/900/1800/1900;
HSPA/UMTS: 850/900/1900/2100 MHz)
For reference, I am on the Virgin Mobile VIP monthly SIM only deal. Virgin don't currently have 4G services but will soon, and I'm wondering if the handset would work on it when it becomes available.
Thanks in advance
AR
dpham00
Moderator Team VP
Moderator
Apr 23, 2011
30,108
200
63
What are the specs of the UK network that you are on?
Sent from my Verizon Samsung Galaxy Note II via Tapatalk 4
thefireguy286
73
4
Verizon LTE phones are SIM unlocked out of the box as has been required per the Block C spectrum regulations. The phone would work on all networks up through HSPA+. Virgin UK is really EE, you will just have to change the default APN settings. As far as I know UK LTE is in entirely different bands (800/1800/2600 i believe) so LTE won't work there on a US Note 3.
Android Rage
16
Thanks for the reply. Would you know how to (where to find related information) change the appropriate APN settings? Also is there a software modification available to change the LTE band reception of the Note 3 (assuming the receiver can receive the UK LTE bands). If the receiver cannot receive UK LTE bands, can a hardware modification be performed?
Thanks
AR
Android Rage
16
Forgive me for asking an easily Google-able question (with regards to changing the APN settings), the answer to which I have just found by googling. I couldn't find answers to the other two questions (software mod or hardware mod).
Cheers
AR
thefireguy286
73
4
Thanks
AR
No and no, they can't be changed. Why not just buy the UK version?
johndoe11
