Results 1 to 4 of 4
Like Tree1Likes
  • 1 Post By Haalcyon
    climb's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Battery Hopeful.......
    I am moving from the best smartphone I have ever owned - my beloved HTC DNA to the Note 3 on Verizon. About the only complaint I have with my DNA is it smallish quickly draining battery - at 2020 mAh and with my power use I am plugged in frequently and make use of my wonderful external hard charger - my Anker - which rocks 15,000 mAh of extra fast charging juice.
    I am looking forward to the larger battery on the Note 3 but worry that with all of the increased functionality of the Note my utilization will only go up and I will use up that extra power quickly. I am hoping the change in the radio technology and the 3.0 USB faster charging helps........
  2. #2
    Haalcyon's Avatar
    Banned
    Posts
    Global Posts
    8,871 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    CM 10.2
    Default Re: Battery Hopeful.......
    Well if you do find your usage increases a lot you'll have the option of getting a larger capacity battery or just another same capacity spare. Gotta love that about Samsung.
    from my Sony Xperia Tablet Z or XTZ or "Ecstasy"
    climb's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I fondly remember earlier Droid phones for which I carried several slim batteries which easily and quickly popped in and out without the bulkiness of a external hard charger. I think HTC, imho, has the best form factor and build quality in the business ( holding a HTC One is glorious......) But I am eager to experience my FIRST Samsung. I hope the aftermarket makes a larger battery for the Note 3 without changing the dimensions and avoiding the size and bulkiness of a extended battery.....now that would really ruin the form factor of the Note 3 and its thinness ......even in my gargantuan hands!!
  4. #4
    Haalcyon's Avatar
    Banned
    Posts
    Global Posts
    8,871 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    CM 10.2
    Well, if the Note 2 and S4 are any indication there will be a plethora of high-quality aftermarket batteries. ...and some that will still fit under the stock battery cover.
    Notrega likes this.
  1. 2 jobs and no outlets means bigger batteries.
    By Rcrdude64 in forum Sprint Galaxy Note 2
    Last Post: 11-02-2013, 01:38 AM
  2. Battery needs calibration?
    By LuisinhoUlisses in forum Google Nexus 4
    Last Post: 09-24-2013, 08:24 AM
  3. S4 drains 15% of battery overnight!
    By nursejel7 in forum General Help and How To
    Last Post: 09-24-2013, 07:06 AM
  4. Ridiculous battery drainage on galaxy s3
    By oddeo in forum Samsung Galaxy S3
    Last Post: 09-24-2013, 12:51 AM
  5. ridiculous battery drainage on galaxy s3
    By oddeo in forum T-Mobile Galaxy S3
    Last Post: 09-22-2013, 12:25 AM
