HELP NEEDED! handwritten text not working on note3
icestrike
4
Hi there!
Having a problem with the handwritten text on the note 3
I have the handwritten box enabled and shown on the note3 screen, however when i write a word/letter, nothing happens in the input field.
Any suggestions?
Thank you
Hi there!
Any suggestions?
Thank you
Return the device and get new one? It might not recognize your writing, but should still show the line while you are writing.
the problem is that it works when i got it
but after changing some settings etc, it din work anymore :(
Even i am facing the same problem i bought my cell yesterday.. and from yesterday night my handwriting text is not working.....
Hi icestrike
I got the solution of our problem....
Change your phone date to 28 see and check weather it's working then change back up date to today's date....
Wow that works! thank you!
if i change to an earlier date in Sep, its okay
but when i change back to the current date, is not working again.
really weird, any reason for such happening?
Hi icestrike
Sounds like a bug.
Should start a bug/problem report thread
Sent from my SAMSUNG-SGH-I337 using Tapatalk 2
So to get the Note 3 to recognize handwriting you have to set an incorrect date? That's not very useful. Wonder how long it will take for a fix for this bug?
I also had this problem
Im in England on EE
What was extra strange was that the other type of handwriting recognition works fine - hover over a text box and you will see a small pen symbol pop up, this brings up a different writing box and it still worked fine.
Changing the date seems to have fixed the problem with the keyboard though
I try to fix the problem by the following step:
- uncheck automatic date and time
- Set date back to 28 sep
- test handwriting to text , and it's work
- then set date back to current date (don't check Automatic date and time)
It's temporary solution.
:'( .....it can't fix the problem. That's still.
This is my first time using an Android...
Now I have a state of the art phone that only works on yesterday's date!
using a singapore model...
doesn't work too... tried and worked when set to september and once back doesn't work..
any other solutions please? will contact samsung here once i get chance to... will keep u guys updated..
Im in England on EE
It's true. The other one works fine. But it is not always available. I hope they'll fix it soon.
on the line with samsung technical helpdesk.. says they know of this problem.. hopefully resolving by end of the week with new updates....
:confused::confused::confused::confused::confused::confused:
Same issue i Norway. I contacted Samsung, they haven't heard of this yet.
Handwriting recognition was fine on my Note 3 until sunday 29th september.
What does the date has to do with this problem?
slackingfred
