You have any PDF files in your internal memory or SD Card? Or DropBox or GDrive is syncing PDF files automatically to device? Looks like index service is not able to handle certain PDF files, so finding that PDF and keeping it out from the device till get a firmware update may be a good try.
Hi there - the problem is not related specifically to PDF files. People keep mentioning this but this is not the problem, as I've tested this myself. My phone does have PDF files on it and right now there is no problem. However, the problem does come back when I add any new file types to the external sd card. These are NOT necessarily PDF files, it occurs with other types as well. My SD card is currently removed to avoid the problem coming back. Before anyone mentions it, it's also occuring with other memory card types, not just the one I'm using now!
I take back my comment... problem now reoccurring, without the sd card installed!!! I'm now investigating files that could be the cause. Painfull! Still no word from Samsung on this!
I've had mine for around 2 weeks and this bug is really starting to bug me. It stops and hangs the phone along with the Samsung WatchOn app that gets stuck. Had my Note 2 for a year and never had any of these problems. Wondering if its the bloatware on the phone which is stopping it. I've stopped the S search, taken out the memory card, and plugged it back in. More of a bug with the phone than anything.
I'm still having this problem. I've got a new SanDisk Ultra Class 10 32 GB micro SD Card based on some of the recommendations in this thread.
I've done a factory reset. I've reformatted the SD card. I've tried working with brand new PDF ebooks. I've worked with older ones. I've renamed
them so that they don't have any periods in the file names, based on what I read over at XDA's forums.
And I'm *still* getting that pesky Index Service message and the freezing. My Note 2 didn't have those problems. I've stopped the S-search thing,
I've done just about everything I can--even talked to Samsung--who claims they've not heard any reports of this problem...and I'd really like to be
able to read some of my ebooks, even if they do open from the SD card, this freezing thing is getting old, pretty fast.
I don't know if I need to go back to Best Buy and talk to the Geek Squad people or not...but I'm getting pretty tempted to do that and see IF it just
might be a defective unit--but I don't know if it's that, given that there's alot of people reporting similar issues here. I'm starting to get pretty damn
frustrated with this...
Kat
aka AnIronButterfly
Stock Black Verizon Note 3, 32 GB w/32 GB SanDisk Ultra micro SD card
