1. memphisboy's Avatar
    I'm considering getting the Note 3 on the Verizon Edge program & immediately placing the phone on my main line instead of activating it on the new line it will come assigned to. I know if it's not activated within 45 days of me receiving it then full payment will be due, but are their any other negatives I may face if I go that route?
    10-03-2013 03:41 PM
  2. nismo591's Avatar
    Are you trying to get a second line and get a N3 with it? If you have an upgrade you are better off getting the subsidized price of 299, edge is bad bc you pay full contract price(have to have an open upgrade to do) when you are better off paying 299 then the early termination fee after a year since that work for be cheaper
    Sent from my DROID RAZR using AC Forums mobile app
    10-03-2013 03:51 PM
  3. SuperTongue's Avatar
    Edge should be looked at more for upgrade usage. Upgrading at 12 months into Edge is basically equal to the current subsidy of the Note 3 - $300. Assuming you upgrade at the 12 month 50% point, it's really not any worse than buying outright. If you aren't utilizing that upgrade in 12 months or well before 12 months, there's really no worth to it. Also, if you like keeping your phone there's no use in it either.
    10-03-2013 04:51 PM
  4. nismo591's Avatar
    But in that case you're better off paying 299 up front and after a year selling the phone and paying the etf that will be lower, you'd make out better that way since you'd get more for it then what the etf would be
    memphisboy likes this.
    10-03-2013 05:01 PM
  5. memphisboy's Avatar
    I'm basically trying to get the phone as soon as it releases and since I'm at max on the number of lines my account can have on the shared plan, this was my only option besides buying it outright.
    10-03-2013 06:29 PM
  6. nismo591's Avatar
    Do any of your lines have an upgrade? You can only do the edge if you have a new line of service added or if you are at your contract end date and available to upgrade.
    10-03-2013 06:33 PM
  7. atrain311qes109's Avatar
    This
    10-03-2013 06:44 PM
  8. memphisboy's Avatar
    My main line does with unlimited data, but the thing is I tried the Edge process as a new customer without signing in to my account and it lets me sign up a single line.
    10-03-2013 07:09 PM
  9. nismo591's Avatar
    Do an alternate upgrade where you use the upgrade buy then activate it to another line, you will retain unlimited data, you will activate the phone to another number but once it's activated switch sim cards and done
    10-03-2013 07:11 PM
  10. memphisboy's Avatar
    Correct me if I'm wrong but in the past if you transfer the upgrade to another line, it would make you change your unlimited to a gigabyte data plan online...unless the system has changed since 6 months ago.
    10-03-2013 08:09 PM
  11. 21stNow's Avatar
    Don't transfer the upgrade to your desired line, just transfer the phone after you upgrade the line that is eligible.
    vzw8830 and memphisboy like this.
    10-03-2013 08:13 PM
  12. nismo591's Avatar
    Initially yes but as long as you do the alternate upgrade and activate the phone on another number your line will remain unlimited, there are a few articles on various tech sites about it check it out but Verizon customer service will do it for you, probably not the store.
    10-03-2013 08:23 PM
  13. nismo591's Avatar
    http://www.droid-life.com/2013/09/17...rizon-upgrade/
    10-03-2013 09:01 PM
  14. buenos's Avatar
    You can trade up every 6 months on edge if your 50% paid off [$300]..I look at it as leasing my phone...and getting whatever is new every 6 months! Crazy...yes...but fun!
    Sent from my VS980 4G using AC Forums mobile app
    10-03-2013 10:24 PM
  1. S-PEN on Note III...Yiccch!
    By NJRonbo in forum Samsung Galaxy Note 3
    Last Post: 11-03-2014, 08:45 AM
  2. How to reinstall Android on netbook?
    By a-dee-jay in forum General Help and How To
    Last Post: 10-04-2013, 08:46 AM
  3. note 3 color pink
    By teri5150 in forum Samsung Galaxy Note 3
    Last Post: 10-03-2013, 07:33 PM
  4. Switched from S4 to Note 3 and loving it....
    By rajnet in forum Samsung Galaxy Note 3
    Last Post: 10-03-2013, 07:08 PM
  5. The coming and going of photo albums on Galaxy Note 10.1?
    By Steve Hopkins1 in forum Samsung Galaxy Note 10.1
    Last Post: 10-03-2013, 02:54 PM
