04-28-2016 12:23 AM
40 12
tools
  1. slide83's Avatar
    Seeing a lot of reports of the Note 3 auto-dimming the screen even with auto-brightness turned off and max brightness selected? I'm curious if this is just a couple of strange instances or a widespread problem. It might be a deal breaker for me since I usually run at max brightness on AMOLED screens.
    10-05-2013 08:44 PM
  2. bitfidelity's Avatar
    Why? Are you a fan of burn-in?
    10-05-2013 08:57 PM
  3. thymeless's Avatar
    If you have it set to adaptive, it might do it then as well.
    10-05-2013 08:57 PM
  4. dontlookatme's Avatar
    on any phone that ive had, if it over heats, it will dim automatically to cool down a bit. it's a great feature, to prevent burnt skin. my droid razr gets to about 116f. and dims for a little bit when it gets this hot.
    10-05-2013 09:04 PM
  5. slide83's Avatar
    Are you suggesting that running a phone at 100% brightness will damage the screen? Don't you think samsung/Motorola know what their screens can take and set the brightness max accordingly or are you just trolling?
    10-05-2013 09:21 PM
  6. zef05's Avatar
    Thank God you created this thread.
    I am having this issue too.
    Although, I am not sure if it does it everytime it heats up. My phone is pretty cool. I mean, cold. You know what I mean.
    Please please pleazeeeee.
    I need a fix. I don't want a dimmed phone!
    I want to enjoy it in FULL HD COLOR!
    Sent from my SM-N9005 using AC Forums mobile app
    10-10-2013 06:13 PM
  7. clevin's Avatar
    it has some adaptive settings, and power saving settings, which will change brightness automatically depends on the content being displayed.
    mrbrodp likes this.
    10-10-2013 06:17 PM
  8. zef05's Avatar
    I made sure those opetions are turned off. But it still happened.
    10-10-2013 06:47 PM
  9. mikedark6699's Avatar
    Make sure your not running samsung knox..I had same issue til I uninstalled it..all good.now running max brightness
    10-11-2013 03:08 PM
  10. zef05's Avatar
    I am not aware of such an app. I'll look into it right now.
    Sent from my Samsung Galaxy Note 3 - SM-N9005 using Tapatalk 4
    10-11-2013 03:18 PM
  11. zef05's Avatar
    How did you uninstall it?
    10-11-2013 03:25 PM
  12. Sooks's Avatar
    Make sure to go to settings/display/Screen Mode/ and change it from adaptive to standard or movie that will allows make it so you dont have to have your screen at 100, which you NEVER should do on any phone....
    10-11-2013 03:52 PM
  13. ScottJohn10's Avatar
    Why not?
    10-11-2013 03:57 PM
  14. Sooks's Avatar
    Why not?
    Realistically it has no effect other than effecting the life of the display, and to be honest even at full brightness it will last the two years or lest most people will own it.
    10-11-2013 04:15 PM
  15. mikedark6699's Avatar
    Samsung knox is a new samsung software that comes bundled on note 3...look In your app drawer and it will be in the samsung folder..if its running that is definitely your issue
    10-11-2013 05:28 PM
  16. Sooks's Avatar
    Verizon and AT&T disabled this app and it wont launch; so this will only be the case if they are on TMO
    10-11-2013 05:29 PM
  17. mikedark6699's Avatar
    Uninstall is tricky..you have to go in your app drawer and actually launch samsung knox and uninstall it through the app..cant be done through setting and applications
    10-11-2013 05:30 PM
  18. zef05's Avatar
    I disabled it.
    What does that do anyway.
    Btw, you guys know how to get the old video player back? I like the stock Video player for the SGN2 better than the one in SGN3.
    That's just me though.
    10-11-2013 05:31 PM
  19. mikedark6699's Avatar
    I disabled it.
    Samsung knox is a new secure based software to seperate business and personal use and secure content... When I checked ram usage it was running apps constantly in both modes basically putting twice the load on the cpu... The software needs to be fixed or note 3's will overheat...it almost killed my phone
    zef05 likes this.
    10-12-2013 01:58 PM
  20. aurangzab2005's Avatar
    have u solved ur brightness issue coz i m having the same.....anything u can tell me plz??
    10-19-2013 02:22 PM
  21. cigar_butz's Avatar
    I have adaptive OFF, I have all power OFF, Autodim OFF, I have Knox OFF. What I have found over the past 2 weeks is that it ONLY dims when running S Note and using the pen! Handset is COLD so its not heating issue. Repeatable as well. Soon after I pull the pen, screen dims down a notch. Shutdown S Note and pull it out of memory (Clean Master) and it goes back to stable brightness.
    10-25-2013 04:22 PM
  22. jenzfc's Avatar
    Oh thank god I am not the only one. When I mostly notice this is when I play PvsZ2. It's really annoying. I already did the screen thing, and I don't have Knox because Verizon is my carrier. What else can I do? This sucks.
    11-01-2013 10:29 PM
  23. Tyler Lietz's Avatar
    I had my note 3 on power saver mode at 40% brightness and I noticed my screen dimmed alittle when my battery hit 59% I thought it was weird cause the current power saving screen setting was doing pretty good and I thought that tiny dim was unnecessary because it just made me turn it up to 50%.
    11-02-2013 04:53 PM
  24. mush10's Avatar
    This is still happening to me. If the overheating was a true cause I would appreciate the feature, but it seems to happen moments after using the device. Hopefully this can be fixed in a software update.
    11-04-2013 01:20 PM
  25. zef05's Avatar
    Is this a bug perhaps?
    Are all note 3 users experiencing this or is this a factory defect?
    11-23-2013 02:28 AM
40 12
  1. Note 3 Lags sometimes and is slow here is how to fix it!
    By society187 in forum Samsung Galaxy Note 3
    Last Post: 03-14-2017, 02:13 AM
  2. How To Add Camera to Lock Screen
    By miviper in forum Motorola Droid MAXX
    Last Post: 10-07-2013, 01:27 PM
  3. Check out Ghost Armor Screen Protector
    By ttexxan in forum Samsung Galaxy Note 3
    Last Post: 10-07-2013, 12:14 PM
  4. Unable to Watch Online Video
    By Justin J in forum Sprint HTC One
    Last Post: 10-06-2013, 03:47 PM
  5. $288.00 Note 3 at Sams Club for Sprint
    By Gadgetlover0408 in forum Sprint Samsung Galaxy Note 3
    Last Post: 10-05-2013, 08:02 PM
