Page 1 of 2 12 LastLast
Results 1 to 25 of 28
Like Tree3Likes
    zef05's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default How to lock Note 3 to LTE/4g signal?
    It has the WCDMA only and GSM only option. But no LTE only option. Help!
    Sent from my SM-N9005 using Tapatalk 2
  2. #2
    Almeuit's Avatar
    Posts
    Global Posts
    23,276 Global Posts
    Mentioned
    5 Post(s)
    Tagged
    0 Thread(s)
    Default Re: How to lock Note 3 to LTE/4g signal?
    Quote Originally Posted by zef05 View Post
    I don't think any phone right now has a LTE only mode. Reason being incase you aren't in a LTE area you can still get service.
    Sent from my T-Mobile HTC One using AC Forums.
    zef05 likes this.
    zef05's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Too bad.
    The constant change from 4g to 3g is draining my batter.
  4. #4
    ki11ak3nn's Avatar
    Posts
    Global Posts
    584 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    AOPK 24 w/ GLaDOS
    That's why I usually just keep my phone in 3G mode until I need to browse or use navigation. Then it's 4G all the way.
    Sent from my Galaxy Nexus using Tapatalk 4
    dc52ltr likes this.
  5. #5
    atrain311qes109's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thankfully, Verizon has my area on 4g lockdown, so I'm happy to avoid that 3g/ 4g issue. I could see how it would effect your battery because when I had the HTC Thunderbolt, 4g was in its infancy and not widespread. My battery was gobbled up quickly.
  6. #6
    zach_alt's Avatar
    Posts
    Global Posts
    236 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Can't do voice over LTE.
  7. #7
    FaTROBoT97's Avatar
    Posts
    Global Posts
    56 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Yep. Pretty much what everyone else here has said. It's going to bounce back and forth if the 4G LTE signal is weak. Bummer for now, but hopefully they turn up the juice to your area.
  8. #8
    Almeuit's Avatar
    Posts
    Global Posts
    23,276 Global Posts
    Mentioned
    5 Post(s)
    Tagged
    0 Thread(s)
    Too bad.
    That's a carrier issue than not your phone. If it's bouncing back and forth that's due to a weak 4g signal. If you could lock onto the 4g signal only your battery would plummet more since it sounds like a super weak signal already.
    boudicca00 likes this.
    zef05's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Almeuit View Post
    Yeah. Usually 1 bar. But still. It's faster. Haha. I usually download big files while at work. But guess I'm stuck with 3g for now.
  10. #10
    Almeuit's Avatar
    Posts
    Global Posts
    23,276 Global Posts
    Mentioned
    5 Post(s)
    Tagged
    0 Thread(s)
    What carrier? Just curious.
    Sent from my T-Mobile Note 3 using AC Forums.
  11. Thread Author  Thread Author    #11
    zef05's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Philippines - Globe Telecom
    Sent from my Samsung Galaxy Note 3
  12. #12
    brian7751's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    hey here is an app you can use to lock the note 3 to lte only its called "Advanced Signal Status" i use it on my Note 3 https://play.google.com/store/apps/d...gnalinfo&hl=en
  13. Thread Author  Thread Author    #13
    zef05's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by brian7751 View Post
    That's the best network app so far.
    Thanks a bunch!
    Sent from my Samsung Galaxy Note 3 - SM-N9005 using Tapatalk 4
  14. #14
    brian7751's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    your welcome im glad i could help
  15. #15
    Livethejourney's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Brian how do you actually use the app to lock to LTE? Thanks!
  16. #16
    mod777's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    The app works.. go into advanced info then device lte only
    brian7751 likes this.
  17. #17
    brian7751's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    yes go to advanced info at bottom then phone info and on the drop box in the middle of the page it will say lte only but if i recall when you are on lte you cant make or receive calls but you can text and receive texts im not 100% sure though
  18. #18
    junprostar's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I'm on AT&T and when I dial *#*#4636#*#* it will open a hidden menu testing. Click on device information there you can change to LTE only.
  19. #19
    Nihad Fuad Zangana's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    dear
    this code *#*#4636#*#* is not working on Note III
    any one can help us to change the network to LTE via a secret codes of Samsung
  20. #20
    dpham00's Avatar
    Posts
    Global Posts
    24,799 Global Posts
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Nihad Fuad Zangana View Post
    dear
    The app posted above will work, though you may need root as Samsung blocked access to that menu on some of their phones after update
    Sent from my Verizon Samsung Galaxy Note 3 via Tapatalk Pro
  21. #21
    brian7751's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    really, that sucks on my droid maxx on kit kat it still works,though i heard it doesnt work on the lg g2 either
  22. #22
    jorgeglenn sanson's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Hi brian , can you possibly help with my note3 (samsung) cant activate signal
    thanks
  23. #23
    Nikolai Jov Mendoza's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    you can just type *#2263# .. from there you will access the service mode and you can choose LTE/4G signal only
    works for S4, Note 3.. (not tried in S3, never got the chance to hold one)
    -GGG
  24. #24
    dpham00's Avatar
    Posts
    Global Posts
    24,799 Global Posts
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Nikolai Jov Mendoza View Post
    -GGG
    This is blocked in some Note 3 variants. You can also use the advanced signal status app which takes you to the same menu. But it was blocked after the aws update on my Verizon Samsung Galaxy Note 3. I would have to root to get to it now
    dpham00, Android Central Moderator
  25. #25
    FBA
    FBA is offline
    FBA's Avatar
    Banned
    Posts
    Global Posts
    2,465 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Wow...no one seems to have caught on to the fact that it's not the switching from LTE to 3G that's eating battery; it's LTE itself. Might help if you researched that 1st.
    LTE drains battery at a good 35% faster rate than 3G/ H+/ HSPA. That's a fact, not a guess. So why would anyone actually want to "lock on" to LTE only??
  1. HTC Droid Incredible 2 Wipped OS Need Help to Reinstall
    By Arms84 in forum General Help and How To
    Last Post: 10-08-2013, 03:34 PM
  2. Replies: 4
    Last Post: 10-08-2013, 12:31 PM
  3. Note 3 Gallery grid option?
    By Mcfly682 in forum Samsung Galaxy Note 3
    Last Post: 10-08-2013, 01:10 AM
  4. Replies: 0
    Last Post: 10-08-2013, 12:25 AM
