Results 1 to 17 of 17
    eman619's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Note 3 Charging Sounds
    Does your note 3 make a charging sound when you plug in your wall adapter and make a disconnection sound. My s4 did that but my note 3 doesn't.
  2. #2
    Nicholas Marangos's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Note 3 Charging Sounds
    Mine only vibrates when plugged in
    eman619's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Is there an option/setting for this?
    eman619's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Anyone else?
  5. #5
    FanOfAnything's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Mine only has a red led notification no vibrate no sound
  6. #6
    aivar24's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    @eman619
    Having the same issues. Only vibrates when I charge my note 3, no sound. What did you do?
  7. #7
    Des Wollaston's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I've set a rule in AutomateIt (available from the play store) to do this. Works perfectly.
  8. Thread Author  Thread Author    #8
    eman619's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    @aivar24
    I did nothing. Left it as is.
  9. #9
    timigin's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Mine only vibrates when I plug it in as well. I assume that none make a sound when plugged into the wall charger?
  10. #10
    timigin's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    No Note 3's that is.
  11. #11
    nacron's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Strangely enough, the ogg files are in the root media folder, but it's not active in the stock rom. Screen on and off is also there.
  12. #12
    emiinn's Avatar
    Posts
    Global Posts
    259 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Would be great if possible. I already imagine the oldskool half life sounds when I plug unplug my phone
  13. #13
    SpookDroid's Avatar
    Posts
    Global Posts
    11,709 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    That's also driving me nuts, too hehe All my older Galaxy devices made the sound, even the Note 10.1 2014 does it... but Note 3? Mute...
  14. #14
    icnmayhem's Avatar
    Posts
    Global Posts
    208 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    drove me crazy, i set tasker to make a sound when i connect power during the day. i use a wireless charger, so i like to make sure i tossed it in the right spot.
  15. #15
    Klein-tyler Moir's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Note 1's do make a charge sound but after update to 4.3 it stopped on mine !!
  16. #16
    Gautam Balsaver's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Red face Re: Note 3 Charging Sounds
    Thanks a million Des Wollaston...you have saved my day cheers
  17. #17
    shotgun1976's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    its as easy as opening play store download PLUG SOUND and wham bam thank you mam. you even get to browse your phone to select your own sound. hope this helps
  1. Problems with note 3
    By ken28117 in forum Samsung Galaxy Note 3
    Last Post: 10-11-2013, 01:53 PM
  2. Another iPhone to Note 3 user here. I have a couple of questions.
    By wayne106 in forum Samsung Galaxy Note 3
    Last Post: 10-09-2013, 04:07 PM
  3. SD Card - What's best for Note 3. What categories are supported?
    By Huntrowmar in forum Samsung Galaxy Note 3
    Last Post: 10-09-2013, 10:23 AM
  4. Question on activating the Verizon Note 3
    By runamuck0870 in forum Samsung Galaxy Note 3
    Last Post: 10-09-2013, 06:56 AM
  5. Note 3 speaker is so weak!
    By Chris Nguyen2 in forum Samsung Galaxy Note 3
    Last Post: 10-09-2013, 03:06 AM
