I would agree this is a bonehead move by Google as Verizon just updated to 4.3 and gone is the possibility of having the important email, text messages, phone apps on the lock screen if a 'pattern' security is used. In the past on 4.2, you could have those apps visible and you could have a quick look and see if you missed a message or phone call or email -- but of course there was security in that you could not access those messages/voicemails/emails unless you unlocked the phone with the pattern. Why did Google remove that option -- who was the brains behind that decision? For sure you can use 'Swipe' security, which is no security, and have the multiple apps on the lock screen, but that is ridiculous since it is no longer a lock screen since it is not locked! Google needs to bring back the option of using "Pattern" or 'Pin" security and still have the option of being able to see notifying apps on the lock screen.
And yes, looked at WidgetLocker for $2.99 and it puts the email and other apps on the lock screen, but it doesn't give you a notification number if you actually received an email, text, or phone call -- so although WidgetLocker is pretty, but also pretty useless.
So, how does one notify Google to restore a simple option?
Cheers,
Pat
