Page 1 of 3 123 LastLast
Results 1 to 25 of 54
Like Tree5Likes
    yankeesxd's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Verizon Note 3 Loose/Wiggly Home Button
    I recieved my black note 3 today and released my home button is loose and wiggles a bit when i press it, sometimes it stays crooked. Has anyone else encounter this problem?
    this is how mines is like,
    Chitown28 likes this.
  2. #2
    bitfidelity's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Verizon Note 3 Loose/Wiggly Home Button
    I just want to say that I am already missing my Nexus's software buttons.
    mastervm likes this.
  3. #3
    Instrumentals's Avatar
    Posts
    Global Posts
    108 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by bitfidelity View Post
    GODDDDDDDDD ME TOO, it was all so simple then
  4. #4
    js0uth's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    yes a little wiggly but doesnt bother me so much.
  5. #5
    kool_zero's Avatar
    Posts
    Global Posts
    70 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Mine is wiggly. I thought about having it replaced, but haven't decided yet. I am trying not to be too picky, but I can't stand much more than what it is doing now.
  6. #6
    Tysonsaurus's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Mine just barely moves...was the same way on my note 2.
  7. #7
    AgentScribe's Avatar
    Posts
    Global Posts
    185 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Noticed it for the first time today though I've read about others who had an issue. Not going to replace the phone though. ... setting it another is more hassle than it's worth. And, sounds like a persistent problem that will creep up on other Note 3s.
  8. #8
    climb's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    This has been a known reported problem it seems on some of the devices. Mine is wiggly too and if I push hard on the left or right side I can make the button skewed. But it really does not bother me in the big scheme of things considering the overall great experience
    I plan on monitoring it for the next two weeks and if it's noticeably worse I will do the within 14 day exchange
  9. #9
    mastervm's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I lucked out for now (*knock knock*). My button seems to be solid. I do miss the gnex soft buttons for sure tho.
  10. #10
    mhettrich's Avatar
    Posts
    Global Posts
    781 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Literally just got home with my Note. Traded in a Moto X for it. I too am seeing that my home button is a bit crooked at times, but it doesn't bother me so far.
  11. #11
    kj11's Avatar
    Posts
    Global Posts
    1,165 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Fortunately mine is solid...no wiggle a at all, perfectly straight
    Posted using my Galaxy Note 3 via Android Central App
  12. #12
    Emperor's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Mine arrived yesderday via Fedex from Verizon. My home button is rock solid. Not completely sold on the GN3 yet (because i love stock android) but i will give it a fair chance. I do love the screen size.
  13. Thread Author  Thread Author    #13
    yankeesxd's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    do you suggest i go ask for a free exchange?
  14. #14
    crester's Avatar
    Posts
    Global Posts
    648 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    The things some people complain about... it's moving like a millimetre!
  15. #15
    GtoJon's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock Note 2
    My note 2, I can see wiggle if I use a magnifying glass ..... my Note 3 is just a tiny bit looser, but not a problem for me Both phones are white
    Cheers, Jon
  16. #16
    Syed Alwi's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    yep... mine also loose... a bit annoying..i hope it not getting worse or i end up trading it with note 2 again..
  17. #17
    dpham00's Avatar
    Posts
    Global Posts
    24,802 Global Posts
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Luckily mine is solid.
    Sent from my Verizon Samsung Galaxy Note 3 via Tapatalk 4
  18. #18
    kool_zero's Avatar
    Posts
    Global Posts
    70 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I went to Verizon and BestBuy yesterday to check out their Note 3s. All of them had loose home buttons, just as bad if not worse than mine. So I suppose I will hold on to mine for a few more days and then go back to see if they have any that do not have this issue.
  19. #19
    climb's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I had a wonderful tempered glass screen protector installed yesterday on my Verizon N 3 at an AT & T store......and a side benefit is that the protector overlays the home button.....kinda buries it.....it was irritating at first feeling the button a bit below the surface of the glass......but now the little wiggle of the button and the little if any visualization of the button's positional integrity is hidden !!!! It was not bothering me anyway........
    - - - Updated - - -
  20. #20
    kool_zero's Avatar
    Posts
    Global Posts
    70 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Which one did you get? I haven't decided on tempered glass or just a Zagg shield.
  21. #21
    dpham00's Avatar
    Posts
    Global Posts
    24,802 Global Posts
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by climb View Post
    - - - Updated - - -
    Do they install it free? How much was it? My Verizon store didn't have any screen protectors for the note 3, and only 3 cases
  22. #22
    climb's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Product called "Bodyguardz" - looks fantastic - feels even better than it looks - zero impact on sensitivity and responsiveness of the screen - kinda expensive but worth it imho.......I wish now I had had tempered glass protection on my previous phones.......used to swear by ZAGG but can say there is no comparison - wow !!
  23. #23
    climb's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Expensive at $45 + tax......but well well worth it - it is wonderful - ZAGG used to be standard but compared to this tempered glass the ZAGG is no longer a contender - installation charge and cause it is glass they can install and reinstall over as many times as needed until it is perfect
    dpham00 likes this.
  24. #24
    Retinella's Avatar
    Posts
    Global Posts
    1,457 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by dpham00 View Post
    When I went to the AT&T store last week to get the glass protector, the associate put it on my phone for free (even when my phone was from T-Mobile!). They were nice and professional (of course, it's because I dropped $45 on a screen protector).
  25. #25
    ct1211's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Give it time, its build quality. mine was solid from 10/4 until yesterday (1 week)
  1. Verizon Note 3 for $90 on contract with in store pickup. Ymmv
    By dpham00 in forum Samsung Galaxy Note 3
    Last Post: 11-12-2013, 09:06 AM
  2. Where is Knox on GTA Verizon?
    By PhabPhan in forum Samsung SAFE and KNOX
    Last Post: 11-02-2013, 07:06 PM
  3. Note III
    By ttrain68 in forum Samsung Galaxy Note 3
    Last Post: 10-11-2013, 08:56 AM
  4. CG101's Verizon Note 3 Unboxin' (Enjoy!!)
    By cg101 in forum Samsung Galaxy Note 3
    Last Post: 10-10-2013, 07:58 PM
  5. Replies: 3
    Last Post: 10-10-2013, 07:49 PM
