1. FailedState's Avatar
    I bought my Note 3 yesterday afternoon. It was at 55% of battery when i opened it for the first time. I started installing apps, putting songs, videos etc until it got to 0% and turned off. i left it all night closed to get to 100%. Today i had the (as the screenshots shows). Brightness in auto and not a lot of usage because. Still the phone after only 3h and 50m is at 38%. This is not normal. Is there something i do wrong or my device has a problem and i have to take it back?
    Thank you for any advice/solution
    Attached Thumbnails Galaxy Note 3 Battery problem... I think!-2013-10-12-16.49.00.jpg   Galaxy Note 3 Battery problem... I think!-2013-10-12-16.49.10.jpg   Galaxy Note 3 Battery problem... I think!-2013-10-12-16.49.18.jpg
    10-12-2013 12:20 PM
  2. Haalcyon's Avatar
    It doesn't look like you have very good mobile signal. I wonder if your phone is working overtime trying to "reach out".
    crester likes this.
    10-12-2013 12:33 PM
  3. FailedState's Avatar
    hmm i will put it in airplane mode and check it out. thanks for the quick answer.
    10-12-2013 12:42 PM
  4. stan23's Avatar
    It looks like you have had the screen on for almost the entire 4 hours. If so, that battery life is normal.
    crester likes this.
    10-12-2013 01:24 PM
  5. zmann's Avatar
    Even with screen on that does not seem right. Like a previous poster said if you have a low signal that could be the issue, or you may just have a bad battery.
    THE BEAST,,NOTE 3. SIZE IS EVERYTHING!!!
    10-12-2013 02:11 PM
  6. TeamPowerstroke's Avatar
    Looked like almost all of the 4 hours was screen time with 38% to spare. That's pretty good actually your looking at probably 6+hours of screen time
    Tappin From My N3
    crester likes this.
    10-12-2013 04:26 PM
  7. AgentScribe's Avatar
    Consider using Juice Defender from Play Store. The free basic mode has doubled my battery life on Note 3....I too suffer from weak signal and I've trained myself to turn off wifi, bluetooth and gps unless I actually need them.
    Indoors, screen brightness is set very low and auto only when outdoors in bright light.
    10-12-2013 04:32 PM
  8. crester's Avatar
    Having your screen on for 4 hours straight and still having half your battery life left is actually pretty good.
    10-12-2013 04:34 PM
  9. zmann's Avatar
    I suppose. Yea that's a reasonable assessment.
    10-12-2013 05:48 PM
  10. Johnly's Avatar
    My problem is I have my screen at 60% bright all day and I can't kill the beast. Hotel California for sure.
    Sent from my SM-N900V using Tapatalk
    Attached Thumbnails Galaxy Note 3 Battery problem... I think!-uploadfromtaptalk1381645099084.jpg   Galaxy Note 3 Battery problem... I think!-uploadfromtaptalk1381645112289.jpg
    jahkure1 likes this.
    10-13-2013 01:18 AM
  11. dontlookatme's Avatar
    The 4G seems to be in all the time. Have you thought about cutting off when it will not be in use? I do this. And it doesn't take long to reconnect to mobile data.
    Sent from my SM-N900V using Tapatalk 2
    10-13-2013 02:25 AM
  12. Clifern Ong's Avatar
    I have a similar but worse issue with my note 3.
    Before this my battery life was just great. I'm using the international snapdragon version of the note 3.
    A few days ago i was prompt to update the phone for some stability improvements. After doing so my battery life drained much quicker, and the phone gets hot when I put it through some multitasking. ( It didn't heat up at the time before the update.) Now my baseband version is N9005XXUDMJ7. stock touchwiz android 4.3
    I've done a factory reset and yet this issue still persists, never downloaded any new apps after the update. Everything's the same.
    Screen on time is 2h 9mins at 36% battery life.
    I need some help with this guys!Galaxy Note 3 Battery problem... I think!-2013-12-19-18-39-47-1-.jpg
    12-19-2013 04:48 AM
  1. Galaxy Note 3 not connecting to AT&T MicroCell
    By BobWire in forum Samsung Galaxy Note 3
    Last Post: 09-26-2014, 08:16 PM
  2. Love or Hate your Galaxy Note 3?
    By jeepzilla in forum Samsung Galaxy Note 3
    Last Post: 07-04-2014, 01:05 AM
  3. Galaxy S4 Wow
    By sparker781 in forum AT&T Samsung Galaxy S4
    Last Post: 11-06-2013, 11:52 AM
  4. Samsung Galaxy S3 rom install question
    By AwesomePalmPre127 in forum Sprint Galaxy S III Rooting, ROM's, and Hack's
    Last Post: 10-13-2013, 08:56 PM
  5. VZW Note 3 First Impressions
    By JoeInCT in forum Samsung Galaxy Note 3
    Last Post: 10-12-2013, 04:48 PM
