Results 1 to 14 of 14
Like Tree2Likes
  • 1 Post By frankdogg
  • 1 Post By icellphones32
  • 1 Post By fkpalm
  • 1 Post By jpr
    Default S-view flip cover - Help
    Hey there guys, I just got my Note 3 today and I am loving it! I also bought the S-view flip cover case with it. I put the case on the phone when I got home and I can't seem to get it to work. It wont bring up the little screen or turn the phone on automatically when I open the case. Could this be a problem with the case/phone or am i doing something wrong?
  2. #2
    Default Re: S-view flip cover - Help
    do you have it set it up? they say it takes a few attempts to get the phone to recognize you are using the case. also, you should check your settings to make sure its enabled for auto unlock (settings / general / accessory)
    MaTtKs1 likes this.
  3. #3
    docprego's Avatar
    Posts
    Global Posts
    40 Global Posts
    Check for the 2 metal pins in the back of the S-view case. There have been assorted reports of cases arriving with these missing and apparently they are crucial for S-view operation.
    yeah, all my settings are correct. I also looked at the back of the s-view case, there arent any metal attachments on it, is that the issue?
  5. #5
    There is also an apparent recall on the S-view cases from Samsung. Might account for the problems you are having and the lack of availability online.
  6. #6
    Yes, without the metal contacts inside the back of the case the phone does not know it is there.
  7. #7
    I had the same problem and fixed it, what you need to do is take out the directions that are in the package the cover came in. There is a little black piece with 2 gold prongs on it. You have to stick that on the inside of the case before you attach it to your phone. THEN, it'll work. I almost threw the package away, good thing I opened up those directions
    ebedner likes this.
  8. #8
    My oem s view case has two gold pins on the back and it is working perfect. Did you purchase original samsung case or copy.
    Sent from my SM-N900P using AC Forums mobile app
  9. #9
    I had a faulty one, and I exchanged it. After you snap it on, you can go to the settings and there's a setting for s view in lock screen section. S view menu will appear there once the case is snapped on. My first case didn't show s view menu in lock screen setting.
  10. Thread Author  Thread Author    #10
    yeah, i think i'll have to exchange mine. I bought it a the t-mobile store, also checked the instruction booklet and the metal piece wasnt on there so yeah...thanks for all your hep guys
  11. #11
    There's a small black with two brass points device which is glued into the back inside part of the S-View case. Mine was stuck to the term sheet. I had to scrape the paper off as it was stuck to the small device. I put a litte dab of white glue and stuck it in the depressed area that is the same shape. WATCH OUT this piece is 4mm x 15mm. It's small
    Bob
  12. #12
    i bought s4 GT-I9505 nd its s view flip cover without those 2 gold pins nd my sensors are not working at all is this the reason behind its behaviour (not working sensors) ????if other please help to recover i've done factory data reset too!!!!!!!!!!!!!!!!!!
  13. #13
    hi all
    the s view setting in the lock screen section is missing i compared it with a friend of mine phone.
    my phone is n9005XXUENA8
    RGDS
  14. #14
    jpr
    jpr is offline
    jpr's Avatar
    Posts
    Global Posts
    1,702 Global Posts
    Quote Originally Posted by rashedshafik View Post
    hi all
    RGDS
    Look under accessory on the general tab.
    rashedshafik likes this.
  1. Music player on S View?
    By RLLangley in forum Samsung Galaxy Note 3
    Last Post: 04-02-2014, 12:27 PM
  2. Help...Galaxy s4 wont play music when I connect to my car through USB
    By kellietruax in forum AT&T Samsung Galaxy S4
    Last Post: 12-13-2013, 11:51 AM
  3. Replies: 7
    Last Post: 11-10-2013, 02:29 PM
  4. Random resets- please help
    By atomic_squid in forum LG Optimus G Pro
    Last Post: 10-15-2013, 07:10 PM
  5. Help Me Pleaassseee
    By Pariah1990 in forum Verizon Droid Incredible 4G
    Last Post: 10-15-2013, 02:36 AM
