Results 1 to 7 of 7
    tlgem's Avatar
    Posts
    Global Posts
    332 Global Posts
    Default Note 3: Screen flashes when charging at nite
    What is making the screen turn on & off when charging at nite?
    Plug the phone in & the screen comes on I shut it off with power button & in a couple seconds the charge lite goes out and then the charge lite and screen come on. This keeps happening repeatedly every few seconds. In morning phone is charged & no screen flashing
    I have checked for Dev screen on, Air gesture etc is turned off, gps off and anything else I can figure might trigger this at nite & tried 3 different micro usb chargers
    Doesnt happen when charging during the day with same chargers
    Have scoured the web & cant find anything about this so Im thinking I have an odd problem going on
    Any help appreciated
  2. #2
    eckl's Avatar
    Posts
    Global Posts
    146 Global Posts
    Default Re: Screen flashes when charging at nite
    Perhaps you can try another AC outlet. The outlet that you plug your charger in may not be supplying current constantly.
    Sent from my SM-N9005 using Tapatalk
  3. #3
    Does it have any info onscreen or normal lock screen? If it's not lockscreen maybe it's the daydream feature...settings..display...daydream?
    Sent from my SM-N900V using AC Forums mobile app
    tlgem's Avatar
    Posts
    Global Posts
    332 Global Posts
    Thanks for the responses
    What I found out so far is the chargers that I was using when the problem started are around 1 amp output
    Haven't had any problem using these on any other phone for over nite charge
    I have sense tried a couple others that are 1.5 & 1.8 amp and am having no problem
    So the phone must be sensitive to anything less than a 1.5 amp charger
  5. #5
    FernleyE's Avatar
    Posts
    Global Posts
    135 Global Posts
    This is also happening to me and it's a recent occurance. Nothing has changed.... except my GS4 recently had an OS up grade. The charger and outlet are the same ones I have been using for last 6 months.
    Any ideas?
  6. #6
    Quote Originally Posted by FernleyE View Post
    Any ideas?
    There's an app that went errant because of the update. There are 2 things to try.
    Get Gsam Battery monitor from the Play store and monitor which app is popping on randomly so you can clear its cache and data. It will tell you, you just have to play with it. OR, you can back up everything and do a factory reset.
    FernleyE and Ric Peller like this.
  7. #7
    FernleyE's Avatar
    Posts
    Global Posts
    135 Global Posts
    Thanks I'll give the app you suggested a try.
  1. App Icons: Apps vs home screen, etc
    By bertsirkin in forum Verizon Samsung Galaxy Note 3
    Last Post: 10-21-2013, 01:20 PM
  2. Data Usage at Strange Times
    By Forsberg21 in forum AT&T Galaxy S3
    Last Post: 10-18-2013, 07:40 PM
  3. Network Unavailable After Flashing New Rom
    By charlieegan3 in forum Samsung Galaxy Note 2 Rooting, ROMs, and Hacks
    Last Post: 10-17-2013, 03:17 PM
  4. Internet browser is talking when I load a page?
    By bluegrizzlies1 in forum Samsung Galaxy Note 3
    Last Post: 10-17-2013, 12:55 PM
  5. Replies: 1
    Last Post: 10-17-2013, 11:17 AM
