1. ZarathustraHead's Avatar
    I'm having charging problems with my Note 3. My battery will show 100% after charging. When I take it off the charger, the battery level will drop like it's hot. Then, when I look at the battery history, it will show that I started at a level well under 100%. Like this:
    Is anybody else having these issues?
    sent from my Note 3
    10-20-2013 12:04 AM
  2. dancing-bass's Avatar
    Seems like the charging circuits need to be reset. Run the phone until it shuts down, leave it powered off, and let it charge undisturbed (if at all possible). Its recommended to do this about every 30 charge cycles to keep the charging circuits (or rather the "fuel gauge") properly calibrated. That is what I would try first. I'm assuming you're using the stock charger and cable?
    10-20-2013 11:35 AM
  3. Samsung888's Avatar
    Same thing happened today?
    Whats wrong?
    01-18-2014 11:39 AM
  4. chloeshotmom's Avatar
    It happened to me a few weeks ago. Called att and sent me a new battery. I have 2 battery now.
    At first I removed the battery and it works perfectly again. But the att replacement battery was on the way that time.
    i love my note 3
    01-18-2014 09:21 PM
  1. Samsung Galaxy Ace - Incoming Message: Memory Full- Help!
    By amy1503 in forum Samsung Galaxy Ace
    Last Post: 01-24-2014, 06:52 AM
  2. Replies: 17
    Last Post: 10-30-2013, 07:55 AM
  3. Samsung GS4 unsupported files/videos
    By Kaner182 in forum Samsung Galaxy S4
    Last Post: 10-21-2013, 07:11 AM
  4. battery problem in rockchip 3066 processor based tablet.
    By amitsethi in forum Chargers and Batteries
    Last Post: 10-20-2013, 07:57 AM
