Results 1 to 5 of 5
    Default Nova Launcher - Causing excessive battery usage?
    Has anyone else noticed Nova Launcher causing excessive battery usage? Or perhaps it is the Nova notification product? I was getting great battery lifted (typically charge every 48 hours or so) and then I installed Nova after I saw all the people's home screens online. I then went to having to charge every 18-24 hours. Anyway, I uninstalled the Nova Launcher and went back to stock Samsung and my battery life is back to awesome again... looking to be 48 hours before I have to charge again for a second time in a row since uninstalling. Of course I also uninstalled some other junk apps I never used so I can't say for certain Nova is the culprit, but curious if anyone else has seen this. I'm newer to Android so just not sure.
  2. #2
    srkmagnus's Avatar
    Posts
    Global Posts
    6,746 Global Posts
    ROM
    Stock 4.4 (KitKat)
    Default Re: Nova Launcher - Causing excessive battery usage?
    If you have an add on installed that could be the problem Nova runs pretty good and is light on battery use.
    Sent from my SPH-D710 using AC Forums mobile app
  3. #3
    Since Nova Launcher is also an app, then it will really cause a fast batt drain. But as far as I know, it wouldnt drain too much.
  4. #4
    I haven't noticed any battery change using Nova Launcher though I don't have the paid version.
  5. #5
    I have the paid version and I get about 25-30 hours with 4-5 hours screen-on time.
  1. loving nova prime :) on my note 3 .
    By Rohit Ramesh1 in forum Samsung Galaxy Note 3
    Last Post: 11-06-2013, 03:57 PM
  2. Phone battery suddenly drains very fast
    By ttsinloong in forum HTC One
    Last Post: 10-22-2013, 08:19 AM
  3. Launchers
    By Jimmy Walker in forum HTC One
    Last Post: 10-21-2013, 08:52 AM
  4. Stuck in bootloop after drained battery
    By fengstar in forum HTC One
    Last Post: 10-20-2013, 05:43 PM
  5. Battery Issues
    Last Post: 10-20-2013, 10:43 AM
B
