1. Romil Majmudar's Avatar
    Hi,
    Just now i have bought Note 3 with one year warranty, after 10days suddenly my proximity sensor stop working means sensor not working during the call, else all functions are working when i have came to know i have checked with *#0*# and checked sensor but ADC is working properly but green light is not able to on... can you suggest how to fixed this may i have deleted few files from application manager.. or please advice how to re-install my jelly bean 4.3.
    Thanks,
    Romil
    10-23-2013 11:34 AM
  2. dallasfever's Avatar
    No fix for it yet. Most people have this issue. Just doesn't come up often as most people are not aware since it's during a call.
    Sent from my SM-N900P using Tapatalk
    10-23-2013 11:17 PM
  3. smurftech's Avatar
    I have the same issue noticed it about a week after i got the phone.
    Proximity sensor locks once activated, small feature but bloody annoying.
    I tried blowing compressed air into the phone which seemed to work for about 1/2 day then went back to locking
    10-24-2013 06:25 AM
  4. mynewride's Avatar
    put me on the list of phones that are having problems with the proximity sensor not working.
    10-24-2013 07:37 AM
  5. johnnyshinta's Avatar
    Hasn't happened on my note 3 yet. Happened on my s4 and it was quite annoying. Seems like an overall Samsung issue
    10-24-2013 10:51 AM
  6. mullarameez's Avatar
    I also suffered the same problem from day 1 on my N900 note3..
    10-28-2013 04:35 PM
  7. zmann's Avatar
    No issue here,, seems to be working properly.
    THE BEAST,,NOTE 3. SIZE IS EVERYTHING!!!
    10-28-2013 05:23 PM
  8. alexlam24's Avatar
    Do you have a screen protector on?
    Sent from my HTC Xperia S4
    10-28-2013 05:32 PM
  9. stan23's Avatar
    pretty sure mine hasn't worked since day 1. If I get a call, the proximity sensor works once, then doesn't dis-engage. Not a real deal breaker, but would be nice if it was working.
    I put on a spigen screen protector since day 1, so i'm not sure if that's the problem. I don't really want to remove it just to check.
    10-28-2013 06:07 PM
  10. mullarameez's Avatar
    Hello everyone. I found the cause of this I hope. The main culprit is hardware. 1st I will tell solution for this problem. Just push hard the earpiece chrome grill inside with ur nails and the proximity sensor will work properly. problem is when we use phone and it gets heated at top then the glue which is holding earpiece grill will loose itself. its hardware problem and eventually many note3 users will face this. im using exynos note3.
    Sent from my SM-N900 using Tapatalk
    11-02-2013 10:34 AM
  11. Samuel Fauteux's Avatar
    I've try what you say, but that's not working... It's my second Galaxy Note 3 with this problem...The first one have been resent to Samsung!
    Someone can help with it? Thank you!
    *Srry for my english, I'm french.
    12-18-2013 04:26 PM
  12. Johnly's Avatar
    My proximity sensor is failing again. pressing on the grill and blowing dust does not seem to be a viable *fix*. I have ordered another note 3. It better work or i will keep ordering them or get another phone. Not as impressed with the note 3 as I was with the note 2 is *some* regards.
    12-18-2013 09:05 PM
  13. FBA's Avatar
    You all do know that there is a setting to turn the sensor on and off, right?
    12-18-2013 09:44 PM
  14. akhil kumar3's Avatar
    Blow air in ear pieces and tap harder with ur finger on proximity sensors n try..... it worked for me.
    02-24-2014 01:00 PM
  1. Caller display not working in landscape mode
    By dakeb in forum Samsung Galaxy Note 3
    Last Post: 01-20-2014, 04:52 AM
  2. Samsung Galaxy Note 8.0 Wifi only tablet Question
    By JKovach1227 in forum Samsung Galaxy Note 8.0
    Last Post: 11-19-2013, 02:19 PM
  3. Is it safe to update fw for note 2?
    By Zergslayer69 in forum Samsung Galaxy Note 2
    Last Post: 10-27-2013, 01:13 PM
  4. Note 3 Consultant Guide - Good Info
    By streetslide in forum Samsung Galaxy Note 3
    Last Post: 10-23-2013, 11:12 PM
  5. pics in text not showing
    By jckd in forum Moto X (2013)
    Last Post: 10-23-2013, 03:48 PM
