Page 1 of 2 12 LastLast
Results 1 to 25 of 31
    Chema Martin's Avatar
    Posts
    Global Posts
    161 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Anybody using the MPJ 4500mah battery?
    The battery on my note 3 is nothing short of amazing, but I was thinking of buying a spare. I read good things about these MPJ ones, specially since they seem to pack a bit more juice and are affordable, without impacting the overall feel of the phone.
    Anybody using this one? Does it really deliver roughly 30% more battery time than stock?
    Thanks
    Sent from my SM-N9005 using Tapatalk
  2. #2
    GtoJon's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock Note 2
    Default Re: Anybody using the MPJ 4500mah battery?
    I don't think so ... at 4500mAh it should be a lot better than just comparable to the stock battery! Don't settle for less! There is lot of better batteries out there, like Anker & Caseology that are rated at the standard 3200mAh!
    Cheers, Jon
    Posts
    Global Posts
    161 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I actually did a bit of research and I don't think it is a good idea to buy these batteries. At 3.7 watt, they are below the stock 3.8 standard, and would therefore deliver about the same endurance, but without matching stock in power.
  4. #4
    GtoJon's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock Note 2
    My Caseology Batteries & charger will arrive today & I will report as to how they do
    Cheers, Jon
    Posts
    Global Posts
    161 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Looking forward to hearing your feedback, thanks!
  6. #6
    CehowardNote7's Avatar
    Posts
    Global Posts
    1,418 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Chema Martin View Post
    Same here..
  7. #7
    GtoJon's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock Note 2
    Quality is top notch ... I have seen it all .... still charging & we'll see what I get after that! I have had batteries where you can tell by the feel that the cells are split in 2. Those are the batteries I have seen that never start at 100% & never last more than 2/3 of the OEM battery. These are not those batteries so far
    Update: Taking a long time to charge .... hope it's worth it .... more later
    Cheers, Jon
  8. #8
    GtoJon's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock Note 2
    After charging for 5+ hours I put it in the phone & it started out at 100% for about 5 minutes & after updating 10 apps on WiFi it's at 99%
    Cheers, Jon
  9. #9
    GtoJon's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock Note 2
    So far the battery is working great! Not much screen time, but have been doing a lot of WiFi file transfers & such
    Cheers, Jon
  10. #10
    Man In Black 805's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I'm on their website and under "Shop By Device", I see nothing there regarding the Galaxy Note 3 under Samsung, where are you finding your battery?
    Quote Originally Posted by GtoJon View Post
    Cheers, Jon
  11. #11
    emiinn's Avatar
    Posts
    Global Posts
    259 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Cheers, Jon
    Looks great I'm searching for a extended battery too but would like to see the performance when your power using it after the 4th, 5th charge
    Btw does this battery add bulk?
  12. #12
    GtoJon's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock Note 2
    The battery is the same size as the OEM Samsung. I hope they work great after 5 charges too
    Amazon.com: Caseology 2 X 3200 mAh Li-ion Replacement Battery for Samsung Galaxy Note 3 with Travel Wall Charger with USB Port (Non-NFC) [18-Month Warranty]: Cell Phones & Accessories
    Cheers, Jon
    Quote Originally Posted by emiinn View Post
  13. #13
    GtoJon's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock Note 2
    Sorry, I'm not a power user ..... you'll be waiting a very long time ..... Average 4 days/Charge x 3 batteries = 12 * 4 = 48 days for 4 charges BTW, 4 days is the lowest average Still on my first charge Battery is the same size as the OEM battery It is lasting at least as long as the OEM
    Cheers, Jon
ID:	89336 Click image for larger version.
  14. #14
    Posts
    Global Posts
    1,418 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    As of now, they are sold out on Amazon.!!
    I had them on order when they were $15.95.. Then I got a note that, they were unavailable..Then they showed up again,and after your good report, they are gone again!!
    EDIT NOTE: When I click on the link to Amazon for the Note 3 batteries, they were unavailable. Five minutes later I click back and again, they were there..
    $16.99 with $2.99 shipping.
    http://www.amazon.com/Caseology-Repl...cUvbUpU3175459
  15. #15
    GtoJon's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock Note 2
    I used the phone a little & put 6h 54m on the screen to help **** this along .... these batteries are great! I also just put in the 2nd battery I charged 3 days ago comes up with 100% charge right out of the gate
    Cheers, Jon
  16. #16
    emiinn's Avatar
    Posts
    Global Posts
    259 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Cheers, Jon
    Are these adding bulk to the phone.? Or are they exactly the same as the stock
    Edit: they're the same size
    But on the site there stands 3200mah
  17. #17
    David_LFC's Avatar
    Posts
    Global Posts
    130 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Don't understand how you are getting that long. Aren't these the same capacity of the standard supplied.
    What do you have enables / disabled
  18. #18
    Posts
    Global Posts
    1,418 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    How sweet it is, I have these batteries coming, and not too long ago, I installed my $8.55 Tempered Glass.. Oh boy!
  19. #19
    GtoJon's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock Note 2
    These are the 3200mAh capacity & my Samsung batts do this well too. I don't do messaging, I pull email from one account every 2 hours, screen is set to about 20%, I do record all my calls mostly for telemarketers. Haven't played any games on it yet.
    Cheers, Jon
    Quote Originally Posted by David_LFC View Post
  20. #20
    David_LFC's Avatar
    Posts
    Global Posts
    130 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Ok that makes more sense
    I get approx 4 hours screen time.
    But have about 10 widgets and loads of things running with auto brightness.
  21. #21
    pauldroidr2d2's Avatar
    Posts
    Global Posts
    2,721 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    ICS 4.0.4
    Thanks
    I'm waiting for the oem batteries. My experiences have been poor ones when I've ventured out to other batteries.
    Sent from my SM-N900V using Tapatalk
  22. #22
    GtoJon's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock Note 2
    I have a Sense Clock Widget & the Google Search widget going, but ... 10 widgets? What are they?
    Cheers, Jon
  23. #23
    David_LFC's Avatar
    Posts
    Global Posts
    130 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Home page
    Dash clock
    Feedley
    App/folder shirt cuts to regular used ones
    Other pages
    Android central 😊
    Rssjunkie
    Bbc news
    S planner list view
    Falcon pro twitter
    Pandora
    Pocket casts
    I heart radio
    Tunein radio
    Daily mail news
    Cnn
    USA Today
    Favourites dialer
    Better battery stats
    Google now
    Independent news widget
    Now I count it I have 19!!!!
    Think I'm a bit obsessed with them😊. But I do use them all. Think Falcon pro is my most popular though.
    Size of the screen and the customisable use of widgets where the 2 key reasons I moved from iPhone 5 to HTC one and then the note 3.
    I regularly achieve 3/4 + screen time with
    -Auto brightness -1
    -Various apps including multiple twitter and Facebook auto syncing
    -Streaming podcasts in my car for 90 mins a day whilst commuting to and from work.
    -push notifications
    I take my phone off charge at 6 am and usually have 10%+ when putting it back on at 10pm at night.
  24. #24
    Posts
    Global Posts
    1,418 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by pauldroidr2d2 View Post
    What is the OEM battery priced at? I have seen the Anker just a single battery in the $18 range. I am going to give these a try. From GtoJon's take, they are working nicely.
  25. #25
    GtoJon's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock Note 2
    $15 & comes with 2 batteries & a charger .... $5 each is way too cheap! I have always used after market batteries in my phones & cameras. The after market batteries sometimes out last the OEM batteries. After only a year with my Canon 7D, my OEM battery started falling off fast & 1 of the after market batteries is still going after 3 years! As far as phones batteries, I have never had a GOOD after market battery fall off on charging ability or capacity! Definition of a good battery is one that stats out after boot at 100% & lasts as long as the OEM battery.
    Cheers, Jon
    Quote Originally Posted by cehowardNote3 View Post
  1. Will I like the Nexus 5/pure android
    By durtNdubs in forum Google Nexus 5
    Last Post: 11-02-2013, 03:05 AM
  2. why is the microphone icon so inconsistent?
    By ManInTheBox10 in forum Android 4.4 KitKat
    Last Post: 10-26-2013, 09:11 AM
  3. Galaxy Note 3 - Battery Issue
    By snake in forum Samsung Galaxy Note 3
    Last Post: 10-26-2013, 07:22 AM
  4. Is there a way to get the TouchWhiz UX from Note 3?
    By cajunbeast in forum Verizon Galaxy Note 2 Rooting, ROMs, & Hacks
    Last Post: 10-25-2013, 05:45 PM
  5. Replies: 0
    Last Post: 10-25-2013, 03:35 PM
