My previous phone was an S3, and I liked my home shortcuts on the lock screen with PIN password security set. Why is this feature gone in Note 3? Is there a workaround?
I dont like the fact that there is no swipe to unlock. For instance, I like to have a 20 minute timer before it locks, and a 2 minute timer before it goes to sleep. Yet I will put it in my pocket after I am done using it, and may take it out in 5 minutes, but when I press the power button or home button to unlock, it doesnt give me an option to swipe to unlock. It just opens up automatically to the home page. I dont like this, since I sometimes accidentally press a button as I am inserting in into my pocket, and the screen will stay on for a while. So I have to input my password everytime I unlock now, or swipe only, and no password.
I will tell you what. I'll never lock my phone so I asked myself "why do you have the lock screen on?" i got rid of it completely and love it. Just hit the button and I'm on my home screen.
THE BEAST,,NOTE 3. SIZE IS EVERYTHING!!!
There is most definitely swype to unlock... you can see it in the image posted above!
I did try this, but it's still not working.
1) I removed PIN security and changed to Swipe
2) Within Swipe, I adjusted the settings to whatever I needed
3) I then went back from Swipe to PIN security and set the PIN.
4) No home shortcuts on the lock screen.
What did I do wrong?
Yes there is a swipe to unlock but I also would like to have a pattern. On any other phone that I've owned. I had the ability to have it locked after 20 minutes. So if I woke it up under 20 minutes. I just had to swipe to unlock only. On this device, if it hasn't locked yet, and I press the home or power button, it goes straight to the home page, or what ever I was doing before. Which I would like to have the ability to swipe and maybe use the lock screen shortcuts and widgets.
Sent from my SM-N900V using Tapatalk
Before I start a new thread, I'm going to post my question here because it deals with the lock screen. I'm going to explain it to the best of my ability because I'm unable to take a screen shot when expanded.
Has anyone had issues of the weather (accuweather) widget popping up expanding, while swiping to unlock the lock screen?
I have tried disabling the widget refreshing (screen shot) or disabling the accuweather widget, etc. Nothing works.
I'm using the swipe method to unlock the screen. If I have a higher security feature, like pattern or pin, it goes away. But I really just want the swipe feature.
It doesn't matter if I have my personal message, owner information message, clock or date. The widget pops up and expand itself. Very irritating.
Please help. I really don't want to load a third party lock screen app on. Or, at least confirm this is happening to you as well.
Thank you for any help you can give me.
http://img.tapatalk.com/d/13/11/02/7yvypyzy.jpg
http://img.tapatalk.com/d/13/11/02/su6ugepa.jpg
http://img.tapatalk.com/d/13/11/02/yzusuqym.jpg
Palm Treo line > Blackberry line > Samsung Galaxy S line > NOW - the Samsung Galaxy Note 3
I feel your pain. I tend to swipe down to unlock, but start too high and it just expands the widget instead. Hate it. Trying to retrain myself to swipe up instead.
