How much battery does your note 3 drain overnight?
dpham00
Moderator Team VP
Moderator
Apr 23, 2011
30,108
207
63
Just curious how much battery your note 3 drains overnight. Mine uses about 3% overnight. What about you?
Sent from my Verizon Samsung Galaxy Note 3 via Tapatalk Pro
was about 4-5. I started turning off any data connection when not in use, it was 0% last night. Update: 4% last night
1-2% if that. I do have social media signed in, but always have refresh set to manual. That way it uses less data & battery.
Palm Treo line > Blackberry line > Samsung Galaxy S line > NOW - the Samsung Galaxy Note 3 😊
Last night it was 2% drain for me... that's pretty normal...
Sent from my SAMSUNG-SM-N900A using AC Forums mobile app
I see about 2%-3% when I sleep less than 6 hours. Today I slept later because of a head cold, so I noticed about 12% drain (granted someone was blowing up my phone and I slept about 9 hours).
I usually charge BUT....
When I don't.. It drains 1-2 % in 6-7 hours. That's probably due to it sitting on wifi while I sleep and using WiFi calling to stay connected to T-Mobile (the cell radio gets shut off).
Sent from my T-Mobile Note 3 using AC Forums.
I plug it in at night,, don't get why anyone would not.
THE BEAST,,NOTE 3. SIZE IS EVERYTHING!!!
I don't because that would keep the battery at high voltage unnecessarily, which reduces the battery's life span.
Not necessarily. Batteries now a days are smart and stop taking charge once full.. It doesn't keep the voltage to it like older batteries... For this very reason :).
I charge it to a 100% before I go to bed and then unplug it. It only drops 2 - 3% over night for me.
Posted via my Samsung Galaxy Note? 3
Yeah, it doesn't really hurt, I just don't like to charge the phone overnight. Plus I use my phone as an alarm clock, if plugged, I might tug it with the cord, happened on an older phone.
You misunderstood, I was not saying it will be overcharge, I meant it will keep battery at the voltage of 4.1-4.2.
Every 0.1 v drop in battery voltage prolongs its life span by significant amount. Sitting at 4.2 overnight is not good.
@T-Mobile GN3
I unplugged mine at 7am.......... when I checked back at 12pm.... it has gone from 100% to 97%... so 3% in 5 hours in stand by..........
Dropped 9% in 6 hours last night..it used to be less (around 5%) before i installed bbm..
Sent from my SM-N9005 using Tapatalk
slackingfred
