Results 1 to 20 of 20
Like Tree1Likes
  • 2 Post By SpookDroid
    Default Flash issues on Note III
    Anyone else having issues with the flash not working on the Note III? I have not seen any posts on this and I am not having issues on my phone but on my wife's phone she is having issues. Her first Note III the flash would not work at all.. verified this with the Tiny Flashlight app. She traded it in for a new phone at Verizon. Now the flash on the new phone will work for a while but then in order to get it to work she has to reboot the phone. After the reboot it works fine. I did not know if there was some setting that might need to be changed.. I think she uses the auto picture mode the most but I know she has tried others when it will not flash. I do not take photos much so I may not see the issue. She on the other hand takes a ton of photos. She also complains about how slow it is to take a photo compared to her iPhone 4s. Any way to speed that up for her?
  2. #2
    Default Re: Flash issues on Note III
    I had the same issue. I don't usually use the flash on a phone so I didn't notice it for the first week or so when I finally decided to try it and couldn't get it to work with either the camera app or flashlight app. I was all set to return it for another one but I rebooted and it's worked fine ever since. Speed-wise I think it's much faster that my wifes iPhone 4S. Loads faster and takes pictures faster. Depending on the light situation I may need to wait for processing but the picture is much nicer than what the 4S can do.
  3. #3
    No issues with mine... I just took a bunch of test pictures with flash forced and it works. I also tried a couple of apps (and the included Torch widget) and it works fine.
  4. #4
    mine works, but it doesnt like to fire in auto mode
    She may be only using Auto Mode. I will have her check when I am off work and try other modes.
  6. #6
    Quote Originally Posted by icnmayhem View Post
    Try turning "Smart Stabilization" off...For some idiotic reason Samsung decided to bundle the "Night Mode" into the stabilization option, so more often than not, the phone will try to take pictures with longer exposure rather than firing up the flash.
    Jalopiejoe and Helene Mack like this.
  7. #7
    I've been having problems with my camera as well. At first the pictures were fine. Then I discovered that the turn flash on and off feature was a little hard to work with. Yesterday I took 10 pictures of my kids in the same pose and some of them flashed, others did not. Today I could not get it to flash at all. Just now I tried removing the Stabilization but that actually darkened the picture for some reason. Still no flash. This is not what I would expect to have to deal with after paying $300.
  8. #8
    I've been having LOTS of flash/LED light issues on my Verizon Note 3. However, I believe this is app related somewhere. Proof is that when I'm under a "full load" of my apps, flash won't fire when using Samsung native camera, under Camera Zoom FX, using the widget Assistive Light, or via any other 3rd party app that offers either camera flash or flashlight functionality.
    If I reboot the phone into Safe mode, it will work just fine. After a reboot from Safe mode back into normal mode, it will work for awhile until I load some number/type of apps (still trying to get to a pattern here) and then the light won't work again until I reboot the phone.
    Generally speaking, I've just learned to reboot my phone first thing every morning after taking it off the charger. Hassle but its Android....you get what you pay for.
  9. #9
    I am having the same problem...tried all the modes but still the led seems to work for ranging (i assume) but then no flash...where are the reset controls?
    Thanks,
    Lawrence
  10. #10
    Mine has been having the same issue. Flash or light doesn't work for anything until I reboot again. I can't believe I bought another samsung piece of sh*t!!
    Also camera sucks even with stabilizer off! Slow and out of focus.
    Quote Originally Posted by gsampl4 View Post
  11. #11
    Why sometime my led notification light will work n sometime don't? Sometime I in lock screen mode the when I receive what apps message the led light will work...n sm in same mode even gt what apps msg...the led light did not work....what happen to my note 3? Anyone have any ideas?
  12. #12
    I have a similar problem. Must restart to get flash to work again
    Sent from my Verizon Samsung Galaxy Note 3
  13. #13
    Really going to crazy with note 3....After updating the led light especially when it charge and also for the message light, it will turn dimmed...don't know why....other notification light work okay...just this two...anyone can help this? Please....
  14. #14
    I absolutely love my Note 3, but I have been experiencing the same thing. After reading your posts tonight, I rebooted my phone and the Flash works fine.
    While it seems a pain, it seems necessary.
  15. #15
    I have been having this issue left and right I thought I fixed it the 1st time when I rebooted my phone. But it happens more often then not and Verizon says that if they can fix it by just rebooting the phone then they can't do anything.
  16. #16
    Do you have any apps that might be 'taking over' the flash? Any 3rd party flashlight apps, perhaps? Try temporarily disabling those and see if it helps (if it does, then you know that it's another app creating a conflict).
  17. #17
    My note 3 flash was not working for about a month now and I didn't know why so I just took out the battery and looked it over and have been looking for a new flash for it. I came across this and seen what was said and just tried my flash and it worked again! Yea!
  18. #18
    Default
    My flash went completely out - even the "light" widget stopped working (which functions by activating the flash). I rebooted the phone (phone off - phone on) and the flash functionality resumed operations.
    I found that a reboot is the fix to many Android function disruptions.
  19. #19
    there is definitely a software problem associated with this, I have noticed the same thing recently on my note 3 my flash stops working. After a reboot the flash will work again. this applies to the camera as well as any other program that uses the flash i.e. flashlight
  20. #20
    Default
    Hey I was having the same problem before I noticed that is was just on my front camera and I didn't notice.. lol silly me, sounds simple but can be confusing, then I put it back on rear camera and properly working with the flash... in the first place I wasn't having any flash because it was on front camera and it has no flash
  1. Nexus 5: Problems & Issues
    By TheDoctor 46 in forum Google Nexus 5
    Last Post: 07-17-2016, 07:44 PM
  2. 64gb Micro SD Card Won't Read on Maxx
    By Jack33 in forum Droid RAZR MAXX
    Last Post: 12-02-2013, 12:03 AM
  3. Sony xperia L - all my songs on my playlists was suddenly gone
    By chel06 in forum Other Sony Android Phones
    Last Post: 11-11-2013, 04:48 AM
  4. Replies: 14
    Last Post: 11-07-2013, 08:10 PM
  5. 64gb Micro SD Card Won't Read on Maxx
    By Jack33 in forum Motorola Droid MAXX
    Last Post: 11-05-2013, 11:23 AM
