The same problem as...? Seeing your screen as the biggest battery gobbler on a device that's nearly 6 inches of full HD glory is not that bad (unless you're keeping the device off at all times... in that case there's something wrong). How much screen "ON" time are you getting off a full charge? How long does your device run on a full battery? Posting a screenshot of the report screen might help
Some tips to reduce battery consumption from the screen are the usual: keep your screen at the lowest brightness you can stand to make it usable, set your 'auto off' settings to the lowest possible (I believe it's 30 seconds), turn your screen off whenever you're not using the device, don't install apps that show notifications on-screen while the device is off like NoLed or "Active Notifications" clones, try to keep darker backgrounds and color schemes (remember, AMOLED uses the least amount of energy while displaying the color black).
