Results 1 to 9 of 9
    Default How to Reset battery stats?
    How do I Reset the battery stats? Also what do the vomits mean in the mobile spot? I tried charging it to full and them turn it off but that didn't work. I also pulled the battery out to and nothing. When I turned it on it showed weird stats. Here is what it looks like...Also does it look like my battery drains fast ?
    Sent from my SM-N900V using Tapatalk
    Attached Thumbnails Attached Thumbnails How to Reset battery stats?-uploadfromtaptalk1384527278678.jpg
  2. Thread Author  Thread Author    #2
    Default Re: How to Reset battery stats?
    Screenshot
    Attached Thumbnails Attached Thumbnails How to Reset battery stats?-uploadfromtaptalk1384527402780.jpg
  3. #3
    An hour with the screen on is normal is think..
  4. #4
    Your stats reset whenever you charge it to 100% and then unplug it. If you are expecting to be at 100% battery and your stats to all be zero, that is impossible. If your phone is on you will have battery stats.
    Looks like you have great battery life. Looks like about an hour of your screen being on, horrible signal quality and you have only lost 15%.
    Quote Originally Posted by missdorado26 View Post
    Screenshot
    Onur Onal likes this.
    The yellowish data means I have bad data service? I still get service though. Maybe I just had super high expectations for this phone. I feel like the battery drains to fast. Do Iphones have the same v problem?
  6. #6
    Quote Originally Posted by sux2bu View Post
    it actually resets when charged to 90%
  7. #7
    Quote Originally Posted by clevin View Post
    This.
    Sent from my T-Mobile Note 3 using AC Forums.
  8. #8
    FBA
    FBA is offline
    FBA's Avatar
    Banned
    Posts
    Global Posts
    2,465 Global Posts
    Screen usage is the single biggest battery-eater. You have 62% of screen usage in an hour and 19 minutes. That means almost an hour of screen-on time in 79 minutes. That's why your battery is now at 86%. Normal. And I am assuming that you had it charged to 100%. If you charged till only 90% and you lost 4% with that type of screen-on time, that's even better. Just sayin...
  9. #9
    I think the reason for resetting the stats is to determine if changes in the power usage make a significant difference. I to would like to know how for that reason alone. So.... anyone??
  1. [App] Easy Search, the fastest way to search in internet!
    By RaiSimo CasiMeli in forum Android App Inventor
    Last Post: 03-10-2014, 02:14 PM
  2. How this Newb successfully sideloaded KitKat
    By brentj in forum Google Nexus 7 Tablet (2013)
    Last Post: 11-15-2013, 01:17 PM
  3. Stock Chrome browser vs Chrome Beta - What is best to use?
    By RickInHouston in forum Google Nexus 5
    Last Post: 11-15-2013, 10:07 AM
  4. Nvidia Shield Wifi killing battery life
    By thoughthalo in forum NVIDIA Shield Portable
    Last Post: 11-15-2013, 09:51 AM
  5. Update from 10.1 to 10.2 has screwed up boot
    By onesojourner in forum General Help and How To
    Last Post: 11-15-2013, 09:07 AM
