ronsimeone
Experienced same problems. After six trips to Verizon, finally a rep told me the Verizon charger would work on my Note 3. Voila! Problem solved
Hi,
just come across this thread as I have the same issue! I woke this morning to 19% charge after 6 hours. Yesterday morning was 67%, it hasn't reached 100% for about a week. I have tried other chargers, removed the battery and place it back and right now, I have the phone turned off charging through the laptop.
When I try to charge it through the mains whilst turned off, it just vibrates every 2 seconds and shows a line across the screen as though something was going to show but stopped. Kind of thing you would see with a knackered screen.
Whilst I type this, I keep getting USB device not recognised as it connects and disconnects however the charge is still showing but doesnt seem to be putting anything into the phone.
The phone knows the charger is in, and shows but nothing is going in.
Would this be a phone or battery issue? Unfortunately I don't have a spare battery to try but have run out of ideas. The battery has been spot on since I bought the phone start of November until this charge issue started a week ago.
Any advice appreciated.
Thanks
I had my phone plugged up all night, it's at 17% and going down fast? It's not charging although it shows it plugged up and under battery settings it says it's charging. I pulled battery- still not charging. Got my note bout 2 months ago, could it be a bad battery?
I'm having same issue. The cord doesn't matter. I've tried multiple ones. The only way it will charge is by turning it off. I'm fighting with my carrier also.I had my phone plugged up all night, it's at 17% and going down fast? It's not charging although it shows it plugged up and under battery settings it says it's charging. I pulled battery- still not charging. Got my note bout 2 months ago, could it be a bad battery?
