1. SpaceJamzz's Avatar
    Wonder if anyone here pairs their Note 3 to their car and then uses the GPS/Maps app and the stock music player at the same time....
    When I do that, when the GPS voice talks, it always misses the first part of what is said...the music stops, but the first few words get cut off...
    However, if the music player if off, the GPS voice works fine and nothing gets cut off. I have tried it with both the regular and high quality TTS options and I get the same result.
    Has anyone else had this same problem? If it makes a difference, I have a 2013 Honda Accord coupe...I didn't have any such issues using my S3 before I got the Note...
    12-02-2013 12:29 PM
  2. rivencap's Avatar
    It's probably user error on my part, but I can't even get gps to work with my bluetooth in my 2012 Ford Edge with Microsoft Sync. I have to turn bluetooth off and run it through the phone's speaker. Was the same with my S3. Can get my calls and music perfectly through it thou.
    Palm Treo line > BlackBerry line > Samsung Galaxy S line > NOW the awesome & powerful Samsung Galaxy Note 3! 😆📱😆
    12-02-2013 12:35 PM
  3. dss2000's Avatar
    I haven't had that problem. I have a Ford Fusion 2013 with MyFord Touch. The music stops and I hear the voice and then music restarts. Are you using Google Maps or another GPS navigation app? Only issue I've had is if I do a voice search sometimes the Navigation will speak over and get entered into Google Search.
    12-02-2013 12:39 PM
  4. SpaceJamzz's Avatar
    using the GPS in the stock Google Maps....I reset the phone, unpaired and the re-paired (LOL) the phone and still the same thing...wondering if it is a Note 3/Honda issue or something...
    12-02-2013 12:45 PM
  5. dss2000's Avatar
    Are you using Samsung TTS? You could try changing to Google TTS to see if that helps.
    12-02-2013 01:05 PM
  6. SpaceJamzz's Avatar
    I only have Samsung TTS under my TTS options...did you download the Google TTS?
    12-02-2013 01:12 PM
  7. SpaceJamzz's Avatar
    I downloaded Google TTS and tried it...same result...
    Also, same thing happens when the Amazon MP3 app is playing...
    However, when I turn off the bluetooth and play back the music and GPS using the Note 3 speaker, it works fine.
    12-02-2013 01:43 PM
  8. dss2000's Avatar
    Yes, its in Google Play. I didn't recall that problem before using Samsung TTS but don't remember. Worth a try though to see if it fixes the issue.
    https://play.google.com/store/apps/d...le.android.tts
    12-02-2013 01:44 PM
  9. SpaceJamzz's Avatar
    seems to be a Honda issue...
    I just did another test with a blue tooth speaker I have and it works fine...Will create a thread in the Honda forum I visit...
    12-02-2013 01:53 PM
  10. Fozzmeister's Avatar
    Duplicate post
    12-02-2013 04:13 PM
  11. Fozzmeister's Avatar
    Same thing happens in my Citron C4 with the stock player. Google Music and N7 pause properly though.
    12-02-2013 04:15 PM
  12. Fozzmeister's Avatar
    Duplicate post
    12-02-2013 04:19 PM
  1. I never get 4G on my Virgin mobile SII
    By brianbotkiller in forum General Help and How To
    Last Post: 12-04-2013, 09:39 AM
  2. Moto X - Do You Use NFC?
    By kobolila in forum Moto X (2013)
    Last Post: 12-03-2013, 08:24 PM
  3. my phone keeps turning on after falling in water
    By benomadridista1 in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 12-02-2013, 03:30 PM
  4. i want to choose which app loads when connecting external
    By butterflies55555 in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 12-02-2013, 03:27 PM
  5. Replies: 0
    Last Post: 12-02-2013, 12:09 PM
