Results 1 to 7 of 7
    Default Note 3 brightness issue
    Hello,
    Sometimes when I press the button to unlock the phone the brighness goes to full for a split second then dimms out to my normal level.
    Eco mode is off
    Brighness on Auto
    I'm the only one with this issue?
  2. #2
    Default Re: Note 3 brightness issue
    Take it off auto brightness and slap that puppy on about 40% or less and try that. It takes a second for the sensors to figure out what the lighting situation is.
    Note 3 / Note 2 / S4 / Moto X / hTc ONE / LG G2
    Works ok with auto brighness on off.. but I really like the auto brightness feature.
    I set it to auto but it's also set to 75%, so when I unlock the phone shouldn't the screen light up to 75%?
  4. #4
    Quote Originally Posted by Chiosc View Post
    No. If auto brightness is checked, it will only use auto brightness and adjust accordingly and immediately (except for the second the sensor needs to adjust). If unchecked it will only use static brightness that you have set. It doesn't use both.
  5. #5
    FBA
    FBA is offline
    FBA's Avatar
    Posts
    Global Posts
    2,067 Global Posts
    It's like what what was posted above, it takes a second or two for it to figure out ambient light.
    Converted lifetime BlackBerry user, now on Samsung Note 3...
    Bye bye Blackberry, forever.
    It hapens at night aswell and it's very annoyng.
    I would like to know if this is a normal thing or should i RMA the phone?
  7. #7
    Mine does it. When you hit the power button, it starts bright then auto adjusts to the ambient light around you. I can't say it's normal for everyone but it doesn't bother me as I turn auto brightness off and use static @ 40%.
  1. HBO Go Buffering Issues
    By macleod52 in forum Google Chromecast
    Last Post: 01-08-2014, 11:04 PM
  2. Sprint Galaxy Note 2 and no PC
    By indysteve9 in forum Sprint Galaxy Note 2
    Last Post: 12-15-2013, 10:29 AM
  3. Screen brightness
    By DS1331 in forum Moto X
    Last Post: 12-04-2013, 10:29 AM
  4. Sound Issues
    By joshsparham in forum Moto X
    Last Post: 12-03-2013, 10:08 AM
  5. Note 3 won't let me post FB status without photo on 4g
    By Zara Arzadon in forum Samsung Galaxy Note 3
    Last Post: 12-03-2013, 08:53 AM
B
