Results 1 to 8 of 8
    Default
    Got massive batt drain overnight
    Can anybody help me interpret this data? Did not happen to me until only yesterday and today..
    Thanks!
    And I was using an S view cover so im pretty sure my phone is in sleep mode, and the screen turns off 30secs of no usage so I dont know why it has been awake most of the time as per stats on wakelock..
    Attached Thumbnails Attached Thumbnails Battery drain-1386284340191.jpg   Battery drain-1386284359061.jpg   Battery drain-1386284381230.jpg   Battery drain-1386284396265.jpg   Battery drain-1386284435781.jpg
  2. #2
    Default Re: Battery drain
    i think there are two things to try:
    1. put a power toggle widget on the desktop to turn off wifi and mobile data before bed, just two taps.
    2. uninstall BBM.
    3200->Centro-->Pre-->Pre2-->HOX/N4-->GN3
    Palm T|X-->Transformer-->Galaxy Tab 7.7-->iconia w510
  3. #3
    BBM was keeping the phone awake.
    Sent from my T-Mobile Note 3 using AC Forums.
    Thank you to the replies above. Yes I have a toggle for those two but my mobile data is not on, I am on airplane mode all night. But yes my wifi is on.
    Another question is why this battery drain is happening just this past 2 days, and not after I installed bbm at its android launch?
  5. #5
    If you do the math those apps aren't keeping your phone awake the 82% of the time. You have 10 hours of wakelock and only a little more than 10 minutes showing there. Your phones battery stats report shows you the culprit. An android service is using up your battery. BBM is not the culprit here. BBM is just waking his phone up more frequently than any other app. It's actually low on the list for total time awake at 18 seconds. So uninstalling it isn't the answer. To find out more go to wakelock detectors settings and choose advanced mode. Google services and or Android system will now be your number one wakelocks click on each one of those and you can pinpoint exactly what's causing it. Do that and post your screen shots.
    Sent from my SAMSUNG-SM-N900A using Tapatalk
    Quote Originally Posted by putsometrebleinit View Post
    Thanks for this, will do. Ill post an update tomorrow morning.
    Sent from my SM-N9005 using AC Forums mobile app
  7. #7
    May I ask what you think is acceptable for overnight drain? I for one mine drops anywhere from 5% to 11%..all depends on the notifications I get but alot of the time I charge it overnight.
  8. #8
    Quote Originally Posted by thegame161 View Post
    I say 0.5 % / hour max.
    Turn off data and wifi before going to bed.
    @T-Mobile GN3
  1. Galaxy S3 4.3 Upgrade - Battery / Charging Issues
    By mbressman in forum Sprint Galaxy S3
    Last Post: 02-07-2014, 12:04 PM
  2. No LTE after Battery Swap
    By BryanEW710 in forum Droid Bionic
    Last Post: 12-10-2013, 10:25 AM
  3. Battery
    By lzelanka in forum Moto X
    Last Post: 12-06-2013, 02:17 PM
  4. KitKat battery bug?
    By Krolt in forum Google Nexus 4
    Last Post: 12-06-2013, 03:43 AM
  5. sdcard process draining battery
    By beckenheim11 in forum AT&T Galaxy S3
    Last Post: 12-05-2013, 03:09 PM
B
