Results 1 to 5 of 5
    Default Android OS is killing my Note 3's battery
    Over the course of about the past week or so, Android OS is killing my Note 3's battery. Sometimes a restart will cure it until the next day when I take it off the charger - at which time it will typically recur. Sometimes a restart will not help. I've audited and removed a number of apps, but so far I haven't been able to cure the problem.
    Is anybody else having issues?
    Note 3
    Note 8.0
    Nexus 10
  2. #2
    Default Re: Android OS is killing my Note 3's battery
    I downloaded Snap Dragon Battery Guru. Seems to have helped my battery life some.
  3. #3
    Quote Originally Posted by blanier98 View Post
    +1
  4. #4
    I went into setting and change a lot of it as well as turning off a lot of the settings. Example: gps, wifi settings, application manager to force stop a few of them, turning off all motion control expect air command, little things like that really add up. If you use them, then keep them on but if not turn it off. Dim your display. You'd just have to play with your settings. There's no real cut and dry answer for this.
    Sent From My Samsung Note 3 using Tapatalk
  5. #5
    stanley08's Avatar
    Posts
    Global Posts
    16 Global Posts
    It's the new ROMs that cause battery issue! Battery Got bad After MJ7 update
  1. Replies: 4
    Last Post: 12-13-2013, 02:17 PM
  2. Lost all events from my calendar
    By moshefriedler in forum Samsung Stratosphere
    Last Post: 12-11-2013, 12:28 AM
  3. Note 2 default font is changed
    By Khalid Hammad in forum T-Mobile Galaxy Note 2
    Last Post: 12-10-2013, 11:20 PM
  4. Emoticons Sense 5.5 Android 4.3
    By soundsreasonable in forum HTC One
    Last Post: 12-10-2013, 01:21 PM
  5. Volume rocker is stiff
    By TofuTwit in forum Moto X
    Last Post: 12-10-2013, 12:42 PM
B
