1. Mouton29's Avatar
    My boyfriend and I both got s3's last year and s beam worked fine. I just got the Note 3 and he tried to s beam me some music and other than the phones vibrating when put together, absolutely nothing happened. We tried vice versa, same story.
    What's going on???
    12-16-2013 08:12 AM
  2. z06mike's Avatar
    Do you both have S-Beam turned on?
    12-16-2013 10:56 AM
  3. wrich2005's Avatar
    I have beamed entire movies to s3s from my note I know for certain it works
    12-16-2013 12:31 PM
  4. pdub73's Avatar
    I had a similar issue when trying to S Beam a group of pictures about 7 of them from my note 3 to my wife's s4 I restarted the phone, did a battery pull and changed batteries and nothing worked so instead of trying to send all 7 pics at once I did one and it worked the I could send the other six all together.... I'm not sure why the S Beam isnt working as reliable as it should but I'm starting to think it's another note 3/Android 4.3 bug
    Sent from my SM-N900V using AC Forums mobile app
    12-16-2013 06:15 PM
  5. SpookDroid's Avatar
    My best friend has an S3 and we had no issues with S-Beam from my old S4 and now a Note 3... so this works.
    12-16-2013 11:46 PM
  6. sux2bu's Avatar
    I have to turn off S Beam and onlyhave NFC on for it to work on both my Note 3 and my wife's S4. With S Beam on it looks like it's gonna work then goes to some dead Google Play store link.
    12-18-2013 09:09 PM
  7. GR cute's Avatar
    Try this.. turn on the NFC and just leave the S Beam off then try if you can send files...
    04-11-2014 06:19 AM
  8. Gator352's Avatar
    Yup same here. We had to turn off S beam and use only NFC to transfer between my Note 3 and my wife's S4.
    04-12-2014 05:22 AM
  9. n8ter#AC's Avatar
    S bean works fine for me to an S4. Use it several times a week. Never an issue.
    Sent from my Galaxy Note 3 using Tapatalk
    04-15-2014 07:27 PM
  10. Trinabean's Avatar
    Thank you!! Thank you!! Thank you!! I couldn't figure out WHY my LG G2 wouldn't receive beams from my Galaxy S3! I kept going to the "dead play store" link too! Turning off the S Beam feature on both and leaving on NFC on fixed it right away!
    07-03-2014 01:58 PM
  11. hleannr88's Avatar
    I had the exact issue you had this week. Except I was trying to go back to the S3 because i had a malfunction with my note3(my fault tho). Use your bluetooth to pair them and then go to my files on your prev device, pick what you want to transfer, then bluetooth them to the other device. I tried everything the previous people said and it didnt work in this case seniorio.
    07-26-2014 05:33 PM
  1. Help! I accidentally droped my phone in a bowl of soap!
    By xZeroNightz in forum Samsung Galaxy S4
    Last Post: 07-11-2016, 11:33 AM
  2. Why I switched from Galaxy S4 to Moto G (in-depth)
    By MrMoto1992 in forum Moto G (2013)
    Last Post: 05-13-2014, 11:24 AM
  3. Samsung Gear won't ring/vibrate when receiving calls
    By Cheimo in forum Samsung Galaxy Gear
    Last Post: 04-13-2014, 01:35 PM
  4. Replies: 1
    Last Post: 12-17-2013, 10:10 AM
  5. Replies: 0
    Last Post: 12-16-2013, 07:43 AM
